This article provides a step-by-step guide for users on how to suggest articles, pages, or sites to their content library using the iOS mobile app. It outlines the process from selecting the content to share, enabling the PostBeyond feature, and editing the text before submission. The article also mentions resources for further assistance and the approval process by administrators.
Learn how to suggest content via the iOS Mobile App. If you find an article, page, or site that you believe would be a valuable addition to your content library, you can suggest it to your Administrators. Once your suggestion is approved, it will appear in the content library. You can also suggest content on the Web and via the Chrome browser extension.
Step 1: Open an article or image you would like to suggest and tap the sharing icon
Begin by locating the article or image that you wish to share. Once you have it open, look for the sharing icon, which is commonly represented by an arrow pointing out of a box or a connected dots symbol, and tap on it to proceed with sharing the content.
Step 2: Scroll to the right until you see the three dots
On your screen, navigate to the right side until the three dots icon becomes visible. This icon typically indicates more options or settings are available.
Step 4: Tap the Three Dots
To proceed with the process, locate and tap the three dots icon. This action will typically reveal additional options or settings that you can access.
Step 5: Enable PostBeyond
Toggle right to enable sharing. You will only have to do this the first time you suggest a post.
After this, you will see that the button has turned green. Once this is done, you will never have to do it again.
Step 6: Select the PostBeyond icon
To proceed with the process, you will need to select the PostBeyond icon. This action is typically necessary to initiate a specific function or to navigate to a particular section of the interface.
Step 7: Select a Photo
Selecting the appropriate photo for your content is crucial. Ensure that the image is relevant and enhances the message you are trying to convey.
Step 8: Edit the text
Editing the text is a crucial part of updating content. Ensure that the text is clear, concise, and free of errors to provide the best experience for the reader.
Step 9: Tap 'Suggest'
After you have made a suggestion for the post, your administrative team will have the opportunity to review it. If the post is approved, it will appear in the content library, and you will be credited as the suggester.
Below are some useful resources to help you get the most out of our mobile app:
- How to Suggest Content via the Mobile App on Android
- How to Share to Instagram via Android
How do I start the process of suggesting content through the iOS mobile app?
Begin by opening the article or image you want to suggest, then tap the sharing icon, which looks like an arrow coming out of a box or a connected dots symbol.
What should I do after tapping the sharing icon to suggest content?
Scroll to the right until you see the three dots, tap on them, enable PostBeyond by toggling right, and then select the PostBeyond icon to proceed.
Do I need to enable PostBeyond every time I want to suggest content?
No, you only need to enable PostBeyond once by toggling right until the button turns green; after this initial setup, you won't have to do it again.
What is the final step in suggesting content through the app?
After selecting a relevant photo and editing the text for clarity and accuracy, tap 'Suggest' to submit your content for review by your administrative team.
What happens after I suggest content using the app?
Your suggested content will be reviewed by your administrative team, and if approved, it will appear in the content library with you credited as the suggester.
