The article provides a step-by-step guide on how to share content from a mobile app to various social networks including LinkedIn, Twitter, and Facebook, as well as other applications. It explains the sharing process, how to personalize the content, and confirms successful sharing with visual indicators. For additional support, it directs users to contact the support team via email.
Depending on which network you would like to share to, there are a variety of methods to do so from the mobile app.
How to Share to LinkedIn & Twitter
Tap ‘Share’ on the post you would like to share.
Swipe to or tap on the icon of the desired social network you would like to share to.
Personalize the post content and tap ‘Share.’
Sharing Options
When tapping ‘Share,' you will have 3 options:
- Tap ‘Share Now’ to share instantly.
- Tap ‘Add to Queue’ to share at a preselected time slot based on Queue Settings.
- Tap ‘Select Date and Time’ to share at a later time by manually choosing a date and time.
You will know you shared successfully if you see a checkmark (if shared) or clock icon (if queued) above the network icon you shared to when you go back to the post.
How to Share on Facebook
Swipe to or tap on Facebook.
Tap 'Share.'
When you tap share, your Facebook app will open with the post to be shared.
Personalize the post and tap 'Post'.
How to Share to Other Apps
Swipe to or tap on the icon with 3 dots to begin sharing to other apps.
Personalize the post content or use the pre-populated content provided.
Tap ‘iOS Share’ to proceed with sharing the content.
You will be able to share the post link and image directly to other applications such as ‘Message,’ ‘Mail,’ and other external apps.
- How to Share to Instagram via Android
- How To Suggest Content via the iOS Mobile App
How do I share a post from the mobile app to LinkedIn or Twitter?
To share a post to LinkedIn or Twitter, tap 'Share' on the post, swipe to or tap the icon of the desired social network, personalize the post content, and then tap ‘Share.’
What are the visual indicators that confirm a successful share on the mobile app?
A checkmark icon indicates a successful share, while a clock icon shows that the post is queued.
How can I share a post to Facebook using the mobile app?
To share a post to Facebook, tap 'Share' on the post, swipe to or tap on Facebook, then tap 'Share' again. The Facebook app will open with the post, where you can personalize it and tap 'Post' to share.
What should I do if I have questions or need assistance with sharing from the mobile app?
If you have questions or need assistance, you can contact the support team at support@postbeyond.com.
Can I share content to apps other than LinkedIn, Twitter, and Facebook from the mobile app?
Yes, you can share to other apps by tapping the icon with 3 dots, personalizing the post content, and using the 'iOS Share' option to proceed with sharing to applications like 'Message,' 'Mail,' and other external apps.
