This article provides a step-by-step guide for users to suggest articles, pages, or sites to their content library admins through the Android app. It emphasizes the ease of sharing content directly from within the app and includes instructions for selecting and editing accompanying images to enhance the suggestion.
If you have found an article, page, or site that you believe would be a valuable addition to your content library, you can suggest it to your admins through the Android app. Once your suggestion is approved, it will be included in the content library. Below are the instructions for suggesting a post from the Android app. For instructions on other platforms, click the following links:
Step 1: Open an article or image you would like to suggest and tap the 3-dot sharing icon
To begin suggesting an article or image, first open the content you're interested in. Then, look for the sharing icon, which typically appears as three dots, and tap on it to access the sharing options.
Step 2: Tap 'Share'
To share the content, simply tap on the 'Share' button. This action will open a variety of options to share through different platforms or applications.
Step 3: Tap on PostBeyond
To proceed with the process, tap on the PostBeyond option on your device.
Step 4: Select a Photo for the Article and Edit the Content
Selecting an appropriate photo for your article can enhance its appeal and convey the intended message more effectively. Once you have chosen a suitable image, you may need to edit the content to ensure it aligns with the visual and the overall narrative of the article.
Step 5: Tap 'Suggest'
If you'd like to suggest a post, you can also do it directly from within the PostBeyond app. This makes suggesting content, including images, incredibly easy.
Suggesting Posts Within the Mobile App
This section provides guidance on how to suggest posts to users within the mobile application. It aims to enhance user experience by personalizing content suggestions.
Step 1: Suggesting Posts Directly from the App
To suggest posts while using the app, simply tap on the 'Suggest' button.
Step 2: Next, tap on the camera icon
After tapping on the camera icon, you will be presented with the following options:
- Suggesting a photo from your images
- Taking a picture
- How to Suggest Content via the Mobile App on Android
- How To Suggest Content via the iOS Mobile App
How do I start the process of suggesting content through the Android app?
Open the content you want to suggest, tap the 3-dot sharing icon, and then tap 'Share' to begin the suggestion process.
What should I do after tapping the 'Share' button?
After tapping 'Share', select the PostBeyond option to continue with your content suggestion.
Can I suggest content directly from within the PostBeyond app?
Yes, you can suggest content directly by tapping the 'Suggest' button within the PostBeyond app.
Is it necessary to select and edit a photo for the article I am suggesting?
Selecting and editing an appropriate photo can enhance the appeal of your suggested content, but it depends on the specific requirements of your content library admins.
What happens after I suggest content through the app?
Once you suggest content, it will be reviewed by your admins, and if approved, it will be included in the content library.
