This article provides a step-by-step guide on how to share content to Instagram using the PostBeyond app on an iOS device. It includes navigation tips, how to edit and share posts, and what to do if the Instagram sharing option is not visible. The article also offers support contact information for users needing additional assistance.
In this article, we will go over how to share to Instagram from an iOS device.
Navigation
To share on Instagram, navigate to the post on the PostBeyond app:
Select Instagram, edit the post and click 'Share' when you are ready to push to Instagram:
NOTE
If you do not have the Instagram Icon, you can click the 3 dots, which will allow you to share the post as a direct message. If you want to share the post in your feed or story and do not have the Instagram icon available for share, please contact support@postbeyond.com. We will contact your company's program manager to see if we can make this available.
You will then go through a series of confirmations before opening Instagram:
Once completed, you will be in Instagram and can choose if you want to post to your feed or your story, edit your post, and then publish it. You can write a caption or paste the auto-copied caption!
Helpful Articles
- How to Share to Instagram via Android
- How To Suggest Content via the iOS Mobile App
How do I share a post to Instagram using the PostBeyond app on my iPhone?
To share a post to Instagram, open the PostBeyond app, select the post you want to share, choose the Instagram icon, edit your post if necessary, and then click 'Share' to push it to Instagram.
What should I do if the Instagram icon is not available for sharing in the PostBeyond app?
If the Instagram icon is not visible, tap the 3 dots to share the post as a direct message. If you want to share to your feed or story and the icon is still missing, contact support@postbeyond.com for assistance.
Can I edit my post before sharing it on Instagram through PostBeyond?
Yes, once you select to share on Instagram, you can edit your post and write or paste an auto-copied caption before publishing it to your feed or story.
Where can I get help if I encounter issues sharing to Instagram from PostBeyond?
If you need help, you can contact the support team at support@postbeyond.com for assistance.
