This article provides a comprehensive guide for iOS mobile app users on how to suggest articles, pages, or sites to be added to a content library, detailing the steps from locating the article to enabling sharing via PostBeyond. It emphasizes the importance of content approval by administrators and includes resources for suggesting content on other platforms and devices.
This article provides instructions on how to suggest an article, page, or site that you believe would be a valuable addition to the content library through the mobile app on iOS. Once your suggestion is approved by the admins, it will be included in the content library.
If you're looking for instructions on how to suggest content using other platforms, please refer to the following resources:
Suggesting Posts via a Third-Party App - iOS
The first time you would like to suggest content with an iOS device, you will need to follow steps 1 through 9. If you have previously completed these steps, you can skip ahead to step 6.
Step 1: Open the Article You Would Like to Suggest
Begin by locating and opening the article for which you have a suggestion. This is the first step in the process of contributing your insights or corrections.
Step 2: Select the sharing icon
To proceed with sharing, locate and select the sharing icon within the application interface. This icon is typically represented by a symbol or image indicative of sharing features.
Step 3: Scroll right until you see the three dots
On your device, scroll to the right within the interface until the three dots, indicating more options, become visible.
Step 4: Select the three dots
Step 5: Enable PostBeyond
Toggle right to enable sharing. After this, you will see that the button has turned green. Once this is done, you will never have to do it again.
Step 6: Select the PostBeyond icon
To proceed with the process, click on the PostBeyond icon. This action will take you to the next step in the workflow.
Step 7: Select Photo
In this step, you will select the photo to be used. Please refer to the image below for guidance.
Step 8: Edit the Text
After completing the previous steps, you can now begin editing the text. This step involves reviewing the text for clarity, accuracy, and consistency, ensuring that it meets the required standards.
Step 9: Select 'Suggest'
Once your content has been approved by your program administrator, you will find it in the content library.
Suggesting Content
Learn how to suggest content on various platforms by following the guides below:
- How to Suggest Content via the Mobile App on Android
- How to Suggest Content - Web App
- How To Suggest Content via The Browser Extension
How do I start the process of suggesting content on the iOS mobile app?
Begin by opening the article you want to suggest, then use the sharing icon and follow the steps to enable sharing through PostBeyond.
Do I need to enable PostBeyond every time I want to suggest content?
No, once you enable PostBeyond by toggling right and turning the button green, you won't have to do it again.
What should I do if I encounter issues while suggesting content?
If you have any questions or encounter problems, you can contact support at support@postbeyond.com for assistance.
Can I suggest content using other platforms besides the iOS mobile app?
Yes, you can suggest content using the Android mobile app, web app, or browser extension by following the respective guides provided in the article.
Where can I find the content I suggested once it is approved?
Once your content suggestion is approved by your program administrator, it will be available in the content library.
