This article provides a step-by-step guide on how to share posts to Instagram using an Android device, including instructions for sharing to both the Instagram Feed and Stories. It covers essential aspects like resizing photos, applying filters, adding captions, and editing Stories, with additional support offered via support@postbeyond.com for any issues encountered during the process.
How to Share to Instagram via Android
Tap 'Instagram Feed' to share to your Instagram.
Navigation
Step 1: Tap the 'Share' icon on the post you'd like to share to Instagram
Step 2: Tap the icon with 3 dots, then tap 'Share'
Note: If you do not have the Instagram Icon, you can click the 3 dots, which will allow you to share the post as a direct message.
If you want to share the post in your feed or story and do not have the Instagram icon available for share, please contact support@postbeyond.com. We will contact your company's program manager to see if we can make this available.
Step 3: Tap Instagram 'Feed' (Post) or 'Stories' to share to your Instagram
Editing and Sharing to Instagram Feed
Editing and sharing photos on Instagram involves a few key steps to ensure your content looks its best and reaches your audience.
Resizing Your Photo
You can resize the photo by adjusting its dimensions. Once you are satisfied with the new size, tap the right arrow to proceed.
Applying a Filter
Choose a filter to enhance your photo's appearance. After selecting a filter, tap 'Next' to continue to the next step.
Adding a Caption and Sharing
Write a caption for your photo or paste one that you've previously copied. Once your caption is ready, tap 'Share' to post your photo to your Instagram feed.
Instagram Stories
Instagram Stories allow users to share images and videos that disappear after 24 hours. The feature provides a way to share moments quickly without having them remain on your profile permanently.
Posting Full-Size Image Posts
When you post an image to your Instagram Story, it will appear in full size. You may need to readjust the image to fit the screen properly.
TIP: If you forget the text that is in the post on PostBeyond, the text will automatically be saved to your clipboard. Click 'paste' and edit the text to fit the Instagram Story.
Editing and Sharing Your Story
After uploading your image, you can continue editing by selecting a filter or other editing options. Once you're satisfied with the edits, you can use the 'Send to' option to share your Story with selected contacts or add it to Your Story for all your followers to see.
Mobile App Guides
Below are guides to help you use our mobile app effectively:
- How to Suggest Content via the Mobile App on Android
- How To Suggest Content via the iOS Mobile App
How do I share a post to my Instagram Feed from an Android device?
To share a post to your Instagram Feed, tap the 'Share' icon on the post, select the Instagram icon or the 3 dots for more options, choose 'Feed' (Post), resize and apply filters if desired, add a caption, and then tap 'Share'.
What should I do if the Instagram share icon is not available?
If the Instagram share icon is not available, tap the 3 dots to share the post as a direct message or contact support@postbeyond.com for assistance in making the feature available.
How can I share a post to my Instagram Story?
To share a post to your Instagram Story, select the post, tap 'Share', choose 'Stories', adjust the image to fit the screen, apply any desired edits, and use the 'Send to' option to share with selected contacts or add it to Your Story.
Is there a way to save the text from a post when sharing to Instagram Stories?
Yes, the text from the post on PostBeyond is automatically saved to your clipboard. You can paste and edit this text when uploading your Instagram Story.
Where can I find more guides on using the mobile app effectively?
For more guides on using the mobile app, you can contact the support team at support@postbeyond.com for assistance and additional resources.
