This article provides a step-by-step guide on using the native sharing feature in the PostBeyond mobile app, enabling users to share content to a wide range of applications beyond the typical social media platforms. It outlines the process from selecting a post to share, personalizing content, and using the native sharing options on both iPhone and Android devices. Additionally, the article lists confirmed compatible apps and offers resources for further assistance.
Learn how to share to other apps outside of LinkedIn, Facebook, and Twitter with our native sharing function. Native sharing allows you to share posts from the PostBeyond mobile app to any other app that permits content sharing. For instance, you can share a post to Instagram, via text message, or in an email using the native sharing feature.
How it works
This section explains the steps you need to follow to share a post from within the application.
Step 1: Find a post you would like to share and tap 'Share'
To begin sharing a post, locate the one you're interested in and use the 'Share' option.
Step 2: Swipe to or tap on the icon with 3 dots
Next, swipe through the options or directly tap on the icon that displays 3 dots to proceed.
Step 3: Personalize the content then tap ‘iOS Share’ on iPhone or 'Share' on Android
Personalize the content as you see fit, then use the ‘iOS Share’ option on iPhone or 'Share' on Android devices to continue.
Step 4: Share the post link and image directly to other applications
Finally, you will be able to share the post link and image directly to other applications such as 'Message', 'Mail', and other external apps.
Once you tap 'Share', the native sharing options will open up, and the image will be copied to your clipboard for easy pasting.
Accepted Apps
Most apps should be able to share content from PostBeyond natively. While we have not tested every app available, the following is a list of apps that are confirmed to work seamlessly:
- Slack
- Snapchat
- Facebook Messenger
- Google Hangouts
- Hipchat
- SMS Text
- Kik
- Tumblr
- VK
If you encounter an app not listed here that does not share content correctly, please contact support or your Customer Success Manager (CSM) for assistance. We may need to investigate the compatibility of the app in question.
Below are some useful resources to help you navigate our platform:
- How to Share to Instagram via Android
- How To Suggest Content via the iOS Mobile App
What is native sharing in the context of the PostBeyond mobile app?
Native sharing is a feature that allows users to share posts from the PostBeyond mobile app to other applications that support content sharing, such as Instagram, text messages, or email.
Can I personalize the content before sharing it using the native sharing feature?
Yes, you can personalize the content to your liking before tapping the ‘iOS Share’ on iPhone or 'Share' on Android to proceed with sharing.
What should I do if I encounter an app that doesn't share content correctly from PostBeyond?
If you come across an app that does not share content properly, you should contact support or your Customer Success Manager (CSM) for assistance, as they may need to investigate the app's compatibility.
Are there resources available if I need help navigating the PostBeyond platform?
Yes, the article mentions that there are useful resources provided to help users navigate the platform, and for any additional support, users can contact support@postbeyond.com.
