The article provides a step-by-step guide for manually scheduling posts on a mobile application, specifically for LinkedIn and Twitter. It emphasizes the importance of selecting the right date and time for maximizing post visibility and engagement, and outlines the process from choosing a post to finalizing the schedule.
If there is a post you would like to be shared at a particular time, you can manually schedule that post. This allows you to choose the date and time at which a particular post will be shared.
NOTE: This feature is currently only available for LinkedIn & Twitter.
Step 1: From your feed, find a post you would like to schedule and tap 'Share'
Step 2: Select which network you would like to schedule it to, then personalize the post and tap 'Share'
Select the social network where you want to schedule your post. After choosing, you can personalize your post as needed. Once you are satisfied with the content, proceed by tapping the 'Share' button to schedule your post.
Step 3: Tap 'Select Date and Time'
After completing the previous steps, you should tap on the 'Select Date and Time' option to proceed.
Step 4: Choose the Date and Time for Your Post
Selecting the appropriate date and time for your post to be shared is crucial for maximizing its visibility and engagement. Consider your audience's time zone and peak activity hours when scheduling your post.
Step 6: When the date is selected, tap 'Done'
Once you have selected the desired date, finalize your action by tapping the 'Done' button.
You will then see that post queued to the time and date selected in the share schedule. You can see which posts you have scheduled and edit them from your 'My Shares' tab.
Explore the following articles to learn more:
- How to Share to Instagram via Android
- How To Suggest Content via the iOS Mobile App
Can I schedule posts for any social media platform using this mobile app feature?
No, the feature to manually schedule posts is currently only available for LinkedIn and Twitter.
How can I edit a post I have already scheduled?
You can edit your scheduled posts from the 'My Shares' tab within the app.
What should I consider when choosing the date and time to schedule a post?
Consider your audience's time zone and peak activity hours to maximize visibility and engagement.
Is there a way to view all the posts I have scheduled?
Yes, you can view and manage all your scheduled posts in the share schedule queue within the 'My Shares' tab.
Who can I contact if I encounter issues with scheduling posts?
You can reach out for support at support@postbeyond.com if you have any questions or encounter issues.
