This article provides a straightforward guide on how to change the name of your PostBeyond platform, detailing a simple four-step process. It emphasizes the importance of having the new name ready and outlines the steps from navigating to 'Settings' to saving the new name. For additional support, the article directs users to contact the support team via email.
Learn how to change the name of your PostBeyond platform. Changing the name of your company or instance can be as easy as 1, 2, 3—as long as you have the new name already in mind. The steps below will guide you on how to make this simple update.
Step 1: Select 'Settings'
To begin, navigate to and select the 'Settings' option in your application.
Step 1: Select Settings
Select the 'Settings' option to configure your preferences.
Step 2: Select 'Company'
Step 3: Fill in your desired name in the space provided
Please enter the name you wish to use in the designated field. This is the name that will be displayed or used in the context of this service.
Step 4: Select 'Save'
Select the 'Save' option to store your changes. This action will ensure that any modifications you have made are not lost and are applied as intended.
Explore the following articles to learn more about various features and processes:
- Alternate Way of Creating a Custom Shortened URL
 - What is an Impression?
 - How to Upload a Company Logo
What is the first step in changing the name of my PostBeyond platform?
The first step is to navigate to and select the 'Settings' option in your application.
Where do I enter the new name for my platform?
You should enter the new name in the designated field under the 'Company' section in 'Settings'.
How do I save the new platform name after entering it?
After entering the new name, select the 'Save' option to store your changes and apply the new name.
Who should I contact if I need further assistance with changing my platform name?
If you require further assistance, you can contact the support team by emailing support@postbeyond.com.
