This article provides a step-by-step guide for uploading a company logo to the PostBeyond platform, emphasizing the importance of using a horizontal logo with specific dimensions for optimal display. It outlines the process from accessing settings to saving the new logo, ensuring users can easily update their social hub's visual identity.
Learn how to upload a logo for your PostBeyond platform to enhance your social hub's visual identity. Horizontal logos are recommended for optimal display. For best results, upload a logo with dimensions of approximately 400 pixels in width and 125 pixels in height to ensure it appears properly on your platform.
Step 1: Select 'Settings'
To begin, select the 'Settings' option from the menu.
Step 2: Select 'Company'
In this step, you will need to select the 'Company' option from the available menu. This action will typically lead you to the company-related settings or information within the application or website.
Step 3: Select 'Upload Company Logo'
To update your company's logo, you will need to select the 'Upload Company Logo' option within the settings of your account. This will allow you to choose and upload a new logo image from your computer to represent your company across the platform.
Step 4: Upload a company logo for your platform
This section will guide you through the process of uploading a company logo to personalize your platform. It's important to ensure that your logo is correctly formatted and sized before attempting to upload it.
Step 5: Select 'Save'
Select the 'Save' option to retain the changes you have made.
Below are some helpful resources that you might find useful:
- Alternate Way of Creating a Custom Shortened URL
 - How to Change the Platform Name
 - What is an Impression?
What are the recommended dimensions for uploading a company logo to PostBeyond?
The recommended dimensions for a company logo are approximately 400 pixels in width and 125 pixels in height.
How do I start the process of uploading a new company logo on PostBeyond?
To start the process, select the 'Settings' option from the menu, then choose 'Company' and proceed to 'Upload Company Logo'.
What should I do after uploading the new logo to ensure it is saved?
After uploading the new logo, you should select the 'Save' option to retain the changes you have made.
Who can I contact if I encounter issues while uploading my company logo?
If you have any questions or encounter issues, you can contact support at support@postbeyond.com.
