This article provides a step-by-step guide on how to organize your email by creating folders and moving content feeds into them within Inbox. It emphasizes the importance of naming folders descriptively for easy identification and outlines the process of relocating a feed using the gear icon, 'Move to Folder' option, and the 'Assign' button to finalize the organization.
Learn how to organize and move a feed into a folder in Inbox to easily find content feed pages. Creating folders to categorize them is suggested. You can create numerous folders for all content feeds you create.
Step 1: Select 'Add Folder' Under the Inbox Tab
To begin organizing your inbox, you can add a new folder. Under the Inbox tab, look for the 'Add Folder' option to create a new place for your emails.
Step 2: Name the Folder
After creating a new folder, you should give it a descriptive name that reflects the contents or purpose of the folder. This will help you and others understand what is stored in the folder at a glance.
Step 3: Select the Gear Icon on the Feed You Would Like to Move
To move a feed, first locate and click on the gear icon associated with the feed you wish to reposition.
Step 4: Select 'Move to Folder'
After selecting the items you wish to move, the next step is to choose the 'Move to Folder' option to organize your files into the desired location.
Step 5: Choose Folder
Under 'Assign subscription to Folder', select the desired folder from the drop-down menu.
Step 6: Select 'Assign'
Once you have completed the necessary steps before this, you can proceed to assign the task or item by selecting the 'Assign' button.
Explore the following resources for more information:
- How to set-up RSS, Twitter, and YouTube feed
- Flow Chart: Differences Between Content Visibility and Newsletters
- How to Remove Inbox Feeds & Why Inbox Feeds Disappear
How do I start organizing my emails into folders in Inbox?
Begin by selecting 'Add Folder' under the Inbox tab, and create a new folder to categorize your emails.
What should I consider when naming a new folder in Inbox?
Give the folder a descriptive name that reflects the contents or purpose, to make it clear what is stored in the folder at a glance.
How can I move a specific feed into a newly created folder?
Click on the gear icon on the feed you want to move, select 'Move to Folder', choose the desired folder from the drop-down menu, and then click 'Assign' to complete the process.
Where can I find additional help if I encounter issues organizing my Inbox?
For further assistance, you can contact support at support@postbeyond.com.
