This article provides a step-by-step guide on integrating Instagram feeds into your inbox by setting up an Instagram hashtag content feed. It outlines the process of linking your Instagram account to your inbox and creating new posts using the content pulled from specified hashtags, thereby enhancing your social brand's promotion.
You can set up Instagram feeds in Inbox to start promoting your social brand. To do this, follow these steps in Administrator View:
Step 1: Tap 'Settings', then 'Integrations'
Step 2: Tap 'Link Instagram'. You will be asked to log in and authorize your Instagram account
Once you have integrated your Instagram account, you can then create Inbox feeds that pull from any Instagram hashtag. See How To Set Up Content Feeds in Your Inbox . Select Instagram hashtag from one of the feed options in the drop-down menu under 'Add New Subscription'.
Content Feeds
Content feeds are an efficient way to stay updated with the latest content. They can be set up directly in your inbox, allowing for easy access and sharing capabilities. Below are resources to help you manage content feeds effectively.
How do I link my Instagram account to my inbox?
To link your Instagram account, tap 'Settings', then 'Integrations', and select 'Link Instagram'. You will need to log in and authorize your Instagram account to integrate it.
Can I create posts directly from the content feeds in my inbox?
Yes, once you have set up a content feed from an Instagram hashtag, you can create new posts directly using the content available in your inbox.
What are the benefits of setting up Instagram feeds in my inbox?
Setting up Instagram feeds in your inbox allows for easy access to the latest content, facilitates sharing capabilities, and helps in promoting your social brand more efficiently.
How do I set up a content feed from an Instagram hashtag?
After integrating your Instagram account, select 'Add New Subscription' and choose 'Instagram hashtag' from the feed options in the drop-down menu to set up a content feed.
