This article provides a step-by-step guide on how to integrate Sendoso's B2B engagement platform with Influitive's AdvocateHub to enhance account-based marketing and sales strategies. It covers the initial account setup, activation of the Influitive Sendoso Integration, and detailed instructions for configuring various types of Sendoso rewards within the Influitive platform, including physical mail, eGifts, and sized items.
Sendoso's B2B engagement platform helps companies amplify account-based marketing and sales with eGifts, handwritten notes, mailers, and more - all in one system.
- Sign up for a Sendoso Account
- Activate Influitive Sendoso Integration
- Setup Gifts in your Storefront
- Configuring Sendoso Rewards in Influitive
Take a look at their offerings, and reach out to the Sendoso team on their website: https://sendoso.com/
There are two parts to this process.
First, you would need to log in to your AdvocateHub as an administrator. Head over to the gear icon > Integration > Search for the Sendoso card and click Manage
Once inside, click on "Enable Integration".
The second part is to contact Influitive Support (support@influitive.com) to enable the Integration from the back-end for your AdvocateHub. Please send us your contact account who has access to your Sendoso Account. Once it's enabled, you should see the following section when creating a new reward. We will also need to jump on a quick 5-minute screen share call with you in order to authenticate your Influitive and Sendosos instances.
If the touch is a sized item then also note the sizes applied to the item.
Please note that you cannot use 'Bundles' with this integration. Only Gift Cards, Physical Items, and Physical Sized-Items.
After the rewards are configured in Sendoso and the integration is connected, Sendoso properties can be configured within the Influitive reward itself to facilitate an integration upon the reward being fulfilled. This setup is different depending on whether the reward is standard physical mail, e-gift, or a sized item.
To ensure a gift can be integrated, please ensure the reward is created as a manual reward. Administrator approval is required whether the administrator approval checkbox is checked or unchecked
I. Configuring Sendoso physical mail Rewards in Influitive
1. If the reward requires physical shipment like a handwritten note, direct mail, or an item without any sized options - the following details need to be filled out in the "Auto Fulfillment Data" section in the "headline" tab within the reward configuration:
- Provider: Sendoso
- Type (Optional): Type of Reward (no space)
- SKU: Touch ID
2. Additionally, you can add a personal message - a custom message that would be delivered to the advocate. This message will populate the Notecard field when the Sendoso reward is sent. You can use the following merge field syntax to customize the message.
- First Name: {{first_name}}
- Last Name: {{last_name}}
- Company: {{company}}
3. Ensure that the "Shipping Information" checkbox is checked for the reward in the "redeeming" tab. This will force the advocate to provide their shipping address upon redemption.
II. Configuring a Sendoso eGift Reward in Influitive
1. If the reward is an eGift the following details are to be filled out in the Auto Fulfillment Data section:
- Provider: Sendoso
- Type: egift | dollar amount (numbers only, no symbols such as $ or £)
- SKU: Touch ID
2. Additionally, you can add a personal message - a custom message that would be delivered to the advocate. This message will populate the Notecard field when the Sendoso reward is sent. You can use the following syntax for advocate fields.
- Last Name : {{last_name}}
3. For eGifts, ensure that the "Shipping Information" checkbox is unchecked
III. Configuring a 'Sized Item in Influitive
Items that require a size mean we have to ask the advocate which size they would like (S, M, L, XL, etc.).
1. If the reward is a sized item, the following details are to be filled out in the Auto Fulfillment Data section:
- Provider: Sendoso
- SKU: Touch ID
2. Additionally you can add a personal message - a custom message that would be delivered to the advocate. This message will populate the Notecard field when the Sendoso reward is sent. You can use the following syntax for advocate fields.
3. In the Reward setup, a custom question needs to be added. Then configure the labels for your sized item as response answers*.
How do I activate the Influitive Sendoso Integration?
To activate the integration, first enable it in your AdvocateHub settings, then contact Influitive Support to enable the integration from the back-end for your AdvocateHub.
Can I use 'Bundles' with the Influitive Sendoso Integration?
No, 'Bundles' are not compatible with this integration. Only Gift Cards, Physical Items, and Physical Sized-Items can be used.
What is required for configuring Sendoso rewards in Influitive?
You need to note the Touch ID from the Sendoso reward URL and configure the reward with the appropriate Auto Fulfillment Data in Influitive, which varies depending on whether the reward is a physical mail, eGift, or sized item.
Do I need administrator approval to integrate a gift with Influitive?
Yes, administrator approval is required for integrating a gift, even if the administrator approval checkbox is unchecked.
How do I ensure that an advocate's shipping information is collected for physical rewards?
Make sure the "Shipping Information" checkbox is checked in the "redeeming" tab of the reward configuration to require the advocate's shipping address upon redemption.
