This article provides a comprehensive guide on integrating ReferenceEdge with Influitive, focusing on setup procedures, configuration of remote site settings, custom settings, and the synchronization of activities between the two platforms. It details how to create Referenceability Types, Event Types, and Challenges, and explains how to activate integration features to manage customer references and advocate marketing programs effectively.
ReferenceEdge rewards Reference Program Members with Points for completed activities. The Influitive Hub likewise rewards Advocates with Points for completed activities. The Reference Program Members in ReferenceEdge and the Advocates in the Influitive Hub are frequently the same ‘real’ person. With this integration, the two systems 'talk to each other' in a number of ways: Issue or redemption of Rewards, Create Nominations or Reference Profiles, Create Challenges, and Update Challenge Status.
Setup
In order to accomplish the integration of Influitive with ReferenceEdge, there are certain settings that need to be configured:
Remote Site Settings
Configuring Remote Site Settings is necessary whenever a user tries to access a third-party site from a Salesforce environment. This ensures that the third-party site the user is accessing is authenticated with Salesforce, providing a first level of security when trying to integrate with them. The steps required for this set-up are as follows:
1. Click the Setup button and type “Remote Site Settings” in Quick Find / Search bar.
2. Click the New Remote Site button
3. Fill the Remote Site Name , Remote Site URL fields and enable the Active checkbox. The Remote Site URL is https://sub_domain.influitive.com
4. Click save .
Custom Settings
The following fields should be populated on the RefEdge Custom Settings page in ReferenceEdge:
- Is Influitive Integration Enabled : This checkbox field should be checked in order to integrate with Influitive. This should be the very last step that occurs after all other Settings have been configured.
- Create Advocate Reference Profile : Check this field to create a Reference Profile for a Contact directly when a new Advocate joins the Influitive Hub. When unchecked, a Nomination will be created in ReferenceEdge.
- Influitive API URL : It is the Influitive URL that ReferenceEdge will access to integrate. The URL will be https://sub_domain.influitive.com
- Create Nominees : Check this field to create a record of Nominee in Invite List (with the Status- Not Invited) in Influitive whenever a new Reference Program Member gets added in ReferenceEdge.
- Influitive Auth Token : It is the Authentication token provided to ReferenceEdge to access the Influitive site. This can be found in the Influitive API Integration card in the Influitive Hub. (Settings > Integrations > ReferenceEdge > Setup)
Influitive Settings
Setup : Go to Settings > Integrations > ReferenceEdge > Setup. Enter the details of the ReferenceEdge org (org id, user id, and password) that you want to integrate. Be sure that the User_ID has sufficient permissions to perform all the activities in Salesforce and ReferenceEdge.
Referenceability Types, Event Types, and Challenge Types
Each Referenceability Type in ReferenceEdge should have an equivalent Custom Event Type in the Hub for the successful creation of an issue transaction. Similarly, a Challenge will be posted to Influitive successfully only when there is a matching API template code in the Hub for the selected Referenceability Type in ReferenceEdge.
Create Referencability Types
- Create a Referenceability Type of the type Non-Reference Activity in ReferenceEdge. It would be logged in ReferenceEdge from Influitive when a Challenge is completed but the Challenge Type does not match any Referenceability Types by name.
- Ensure that for each Referenceability Type the Challenge Type and Referenceability Code are populated with the same API Code as seen in the associated Event Type in the Hub.
Note: Please append these API codes with 'refedge_'. For example, if you have one called 'site_visit' it should be 'refedge_site_visit'
Create Event Types
Go to Settings > Scoring & Achievements > Event Types.
Create an Event Type for each ReferenceEdge Referenceability Type that could be posted to Influitive. For example:
- Create a Custom Event of the type Non-Reference Activity with the API Code – Non-Reference Activity. It would be logged in Influitive from Reference Edge when there is a logged Reference Activity where the Referenceability Type did not contain an Influitive Event API Code.
- Create an Event Type with API code – expired rewards. This allows you to run the batch “Sync Rewards to Influitive”.
Create Challenges
- Create challenge templates for each ReferenceEdge Referenceability Type that could create a Challenge.
Each ReferenceEdge Referenceability Type that could create a Challenge will be categorized under the Challenge Type “Reference”.
- Ensure that the API Template Code for each Challenge Template matches the Referenceability code for each Referenceability Type (ReferenceEdge > Referenceability Types > Influitive)
ReferenceEdge:
Influitive:
Activation
Functionality
Sync Points
Send Advocate's Challenge participation, referral progression, and any Point adjustments to ReferenceEdge with Reward transactions.
Send Challenge Status
Synchronize the Challenge Status (Published, Unpublished) back to the Reference Request in ReferenceEdge when the Request is tied to a Challenge.
Send Advocates
Create new Reference Profiles or Nominations within ReferenceEdge when a new Advocate joins the Hub.
What are the initial steps to integrate ReferenceEdge with Influitive?
The initial steps include configuring Remote Site Settings in Salesforce, customizing settings in ReferenceEdge, setting up Influitive with the necessary credentials, and ensuring corresponding Referenceability Types and Event Types are aligned between the two systems.
How do you configure Remote Site Settings for the integration?
In Salesforce, navigate to Setup, search for "Remote Site Settings," create a new remote site with the appropriate name and URL (https://sub_domain.influitive.com), and ensure the Active checkbox is enabled before saving.
What is the purpose of synchronizing points and challenge statuses between ReferenceEdge and Influitive?
Synchronizing points and challenge statuses allows for seamless tracking and rewarding of advocate activities across both platforms, ensuring that Reference Program Members and Advocates are recognized for their participation and contributions.
How do you create a new Referenceability Type in ReferenceEdge?
To create a new Referenceability Type, append the API codes with 'refedge_' (e.g., 'site_visit' becomes 'refedge_site_visit') and ensure it corresponds to a Custom Event Type in Influitive for successful issue transactions.
What happens when a new Advocate joins the Hub in Influitive?
When a new Advocate joins the Hub, the integration allows for the creation of new Reference Profiles or Nominations within ReferenceEdge, thereby updating the system with new potential references.
