The article provides a detailed guide for administrators on how to manage the approval process for challenges and rewards within a system. It outlines the functions of the "Items to Review" page, the steps to approve or decline challenge submissions, and the actions to take when an advocate redeems a reward, including approving, declining, or marking as fulfilled, with an emphasis on the importance of following established criteria.
What is the Items to Review page?
This page, accessible from the "Items to Review" tile on the Admin View Dashboard, allows you to approve challenge submissions and reward redemptions.
Challenges will appear here if it uses a Corporate Workflow stage and rewards will appear if they are set to require administrator approval or they have been redeemed by an advocate who has never had a reward approved before (we refer to these advocates as untrusted ).
Review Actions: Challenges
- Approve: Advance the advocate to the next stage and award the points associated with the current Corporate Workflow stage. If this is the final stage of the challenge, the challenge will be marked as completed. Important: You cannot undo this action if the challenge becomes completed.
I'd like the Advocate to try again : Send the advocate back to a previous stage of your choosing. The points associated with the stage(s) will be deducted if you send them back more than one stage.
- If the advocate is only sent back to the previous stage, the points for the current Corporate Workflow stage simply will not be awarded.
- The Advocate will be able to edit their response.
I do not want the Advocate to continue this Activity: This challenge will be moved to the "Completed" tab of the advocate's "Challenges" page with no points. The advocate will not be notified, but should they look for the challenge in that tab they will see that it is declined.
- Provide feedback only : If you do not wish to perform any action on the status of this challenge, and only send an update, you may choose this option. It will send a message to their in-Hub messaging inbox.
Each of the above actions allow you to choose the "Provide Feedback" option if you would like to provide reasons for your decision.
Review Actions: Rewards
Decline Redemption : The Advocate will have their points refunded and will receive a message stating that their redemption was declined (see image below).
Approve Without Fulfilling: This approves the reward that the advocate has redeemed without fulfilling the reward. This allows for the reward to be fulfilled later via the API via an external reward integration or manually by an admin at a later time. Once approved, the confirmation will appear like so:
Mark Fulfilled:
- Manual Rewards: This indicates to the advocate that you have manually sent or fulfilled their reward for them
- Automatic Rewards (Tango Card, Sendoso, etc): This will debit the associated account and automatically send the reward via the integration.
- Once fulfilled, the user will receive a notification that their reward is on it's way.
What is the purpose of the "Items to Review" page?
The "Items to Review" page is part of the Admin View Dashboard designed for approving challenge submissions and reward redemptions, ensuring they meet established criteria.
What actions can an administrator take when reviewing a challenge submission?
An administrator can approve the challenge, send the advocate back to a previous stage, decline the advocate's continuation of the activity, or provide feedback only.
What happens when a reward redemption is declined?
If a reward redemption is declined, the advocate's points are refunded, and they receive a message informing them of the decline.
What does marking a reward as fulfilled indicate?
Marking a reward as fulfilled indicates to the advocate that their reward has been processed and is on its way to them.
Can an administrator undo the approval action once a challenge is completed?
No, once a challenge is marked as completed after approval, the action cannot be undone.
