This article provides efficient strategies for signing up new Advocates at events. It outlines the use of Join URLs and QR codes, highlights the importance of privacy during the sign-up process, and advises against certain practices to avoid delays and complications.
Discover the best practices for Advocate recruitment at events, including step-by-step instructions for using Join URLs and QR codes, and learn what to avoid for a smooth experience.
Using A Join URL
A straightforward option for signing up Advocates is using a Join URL. The steps to follow are:
- Create your group and Join URL.
- Open a browser in an incognito/private window.
- Enter the Join URL.
- The advocate will be presented with the opportunity to enter their email address, name, and password.
It's recommended to use an incognito/private window to prevent storing the previous Advocate's information in the browser. Ensure to close the window after each sign-up to avoid issues with information retention.
Using A QR Code
A QR code containing the Join URL can be created using free online services like QR Stuff. While iPhones typically have built-in QR readers, Android users may need to download an app to scan the QR code.
Things To Avoid
Avoid pre-uploading Advocates or adding them manually during the event, as this can cause delays. Also, note that the AdvocateHub App does not support new Advocate sign-ups and will display an error if attempted.
For additional tips on recruiting Advocates at events, join the discussion on VIP - How to Recruit Onsite at an Event.
What is the recommended way to sign up Advocates at an event?
Using a Join URL in an incognito/private browser window is recommended for quick and secure sign-ups.
Can Advocates sign up using the AdvocateHub App?
No, the AdvocateHub App does not allow for new Advocate sign-ups. Attempting to do so will result in an error message.
Is it necessary for Android users to download a QR reader app to scan the QR code?
Yes, if the Android device does not have a built-in QR reader, the user will need to download a QR reader app.
