The article provides a comprehensive guide on leveraging marketing automation tools such as Marketo and HubSpot to enhance the process of inviting advocates to join platforms like Influitive VIP. It emphasizes the importance of pre-populating email addresses in sign-up forms and customizing group invite URLs to improve user experience and streamline the invitation process.
If you opt to use a marketing automation system (Marketo, Eloqua, Hubspot, Pardot, etc) to invite advocates into your AdvocateHub, you will need to make use of a Group Invite URL. The invite URL is a generic link which will allow anyone who receives it to join your Hub. It will come in a form which looks like this
https:// yourhubname .influitive.com/join/{join code}
If you use a custom domain, the /join/{join code} portion will be appended to the end of your custom domain e.g. http:// yourhubname.yourcompany. com/join/{joincode}
Where {joincode}is the group's join code.
Take a look at the Anatomy of a Group article to learn about where to find and configure group join code. This article will also help you to find existing group Invite URLs.
IMPORTANT: This is not a "vanity URL." The Invite URL must be used as is. Do not use the URL which this link redirects to. If modified, advocates may not be able to join.
Pre-populating the Email Address on Sign Up
Advocates may use any address they wish to when signing up for your Hub. Since your CRM system likely identifies customers based on their work email, this may cause problems when you are trying to import customer information from Salesforce .
Luckily, AdvocateHub has a solution to encourage advocates to use a certain email address. Using your Marketing Automation System, you can easily have the email address of the receiving individual be populated when they click on your Invite URL.
All you need to do is add the following to the end of your Invite URL when you are inserting the link into your invitation email:
?email= {email token}
In the above {email token} represents your marketing automation system's email token. You should add the token which is appropriate for the system you are using.
What does it look like to the Advocate?
Here's what would happen if I invite an Alice to Influitive VIP and I want her to use alice@advocate.com:
1. Alice clicks on this link: https://vip.influitive.com/join/joinupfast ?email=alice@advocate.com
2. Her email is automatically pre-filled (as shown below).
Example: Using Marketo
Add the following to the end of the Invite URL when inserting your link into the email:
?email={{lead.Email Address}}
For example, if I want to invite advocates to my Hub using this URL https://vip.influitive.com/join/joinupfast , I just need to make sure the URL of my join button or link is this:
https://vip.influitive.com/join/ joinupfast ?email={{lead.Email Address}}
Here's how that looks in Marketo's URL editing tool:
Example: Using HubSpot
?email={{contact.email}}
https://vip.influitive.com/join/joinupfast ?email={{contact.email}}
Here's how that looks in HubSpot's "Edit link" pop-up:
Please note that if SSO is enabled on your hub there may be some extra things you need to think about regarding Nominees, please read more here . (https://support.influitive.com/solution/articles/3000052818#invites)
How does pre-populating email addresses in sign-up forms benefit the invitation process?
Pre-populating email addresses reduces friction for potential advocates, making it easier and faster for them to join the program, which can lead to higher conversion rates.
What is a Group Invite URL and why is it important?
A Group Invite URL is a generic link that allows recipients to join an AdvocateHub. It is crucial to use this URL as provided without modifications to ensure successful advocate registration.
Can I use a custom domain for my Group Invite URL?
Yes, you can use a custom domain for your Group Invite URL, but you must follow the specific format provided and include the group's join code.
What should I do if there is a discrepancy between the email addresses used by advocates and the ones in my CRM system?
You can encourage advocates to use their work email addresses by leveraging your Marketing Automation System to pre-populate the email field in the sign-up form with the recipient's email address when they click on your invitation link.
Are there additional considerations for using marketing automation systems with hubs that have SSO enabled?
Yes, if Single Sign-On (SSO) is enabled on your hub, there may be additional steps or considerations for nominees. It is recommended to read the detailed guide provided for SSO and nominees in Influitive Hubs.
