The article provides a comprehensive guide on integrating OAuth 2 authentication in AdvocateHub, detailing the Single Sign-On and Dual Login flows, compatibility with join URLs/codes, and the process of inviting nominees and advocates. It addresses potential issues with existing users during the transition to OAuth 2 and offers strategies for a smooth changeover, including proactive measures to prevent account duplication. Additionally, it explains how to set terms and conditions and how the AdvocateHub app supports OAuth 2 for mobile access.
- What does the flow look like from the Advocate point of view?
- Do Join URL/Codes work with OAuth 2?
- How do invites work with SSO?
- Things To Think About If Implementing SSO On An Active Hub
- Can I have some Advocates use OAuth 2 SSO but others to use the traditional method of login?
- Where are the 'Terms and Conditions' housed when using SSO?
- How does the AdvocateHub app work with SSO?
Using OAuth 2 Single Sign On
- Navigate to the AdvocateHub URL
- They will be immediately be redirected to the login screen you have configured as your login point for your Advocates
- Advocate enters the AdvocateHub
Note: If an advocate is already a member of another AdvocateHub with the same email address then there is one additional step in the flow. After they successfully enter their credentials into the customer portal, they will see a message like below:
An email will be sent to the Advocate which will include a link which they just have to click on and they will be brought back to the login screen to enter their credentials once more before gaining access to the AdvocateHub.
Here is a visual walkthrough of the flow the Advocate will experience:
Using OAuth Dual Login
The flow for the advocate is as follows:
- They will be brought to the AdvocateHub Sign In page. They will be greeted with the opportunity to login through the Single Sign-On or click Click here to Sign In to reveal the regular login form where they can enter their email & password and access the Advocatehub:
Yes. You can use these exactly as you would normally expect with the AdvocateHub.
How do invites work with OAuth 2?
Important Note about Nominees and SSO
If you have a Nominee in your AdvocateHub and then this user tries to sign up to the AdvocateHub using a join URL or by navigating directly to the AdvocateHub they will experience permissions issues. Currently, the only way to 'upgrade' a Nominee to an Advocate is by sending them an invite directly from AdvocateHub, they will then need to click the link contained in the invitation to gain access to the AdvocateHub as an Advocate.
To study some other options on how you can segment your Advocates check out this article .
Things to think about if implementing OAuth 2 on an active Hub
In this case I try to access the hub and am directed to your product or platform to complete the login process. I enter sean@influitive.com and my password and enter the hub successfully but now I will have a brand new account setup as the AdvocateHub did not have an email address sean@influitive.com present, it was looking for sean@gmail.com.
What can you do to prepare for this?
Yes. With OAuth 2 you can choose to enable Dual Sign-On, this allows your Advocates to choose whether to login through Single Sign-On or using the traditional email/password method. This may be helpful if you have Employees and Customers in your program and you would like your employees to use Single Sign into login but your customer to use their email and password.
This is what will greet the Advocate when they navigate to your AdvocateHub if you have Dual Sign-On enabled:
In order to find out how you can switch between Single Sign-On and Dual Sign On have a look at our Configuring OAuth 2 article.
Where are the 'Terms and Conditions' housed when using OAuth 2?
You can set the Terms & Conditions under Settings > Advocate Program > Sign-In. Simply enter your desired Terms & Conditions and toggle 'on'.
How does the AdvocateHub app work with OAuth 2?
Can join URLs/codes be used with OAuth 2 in AdvocateHub?
Yes, join URLs/codes are fully compatible with OAuth 2 as implemented in AdvocateHub.
How can I ensure a smooth transition to OAuth 2 SSO for existing users in an active hub?
To ensure a smooth transition, communicate the changes to your Advocates and encourage them to update their email addresses. Proactively cross-reference email addresses and create accounts to prevent duplication, and consider merging accounts if necessary.
Is it possible to have some advocates use OAuth 2 SSO and others use traditional login methods?
Yes, OAuth 2 enables Dual Sign-On, allowing advocates to choose between Single Sign-On or traditional email/password methods.
How do I set Terms & Conditions for my Advocate Program when using OAuth 2 SSO?
Set the Terms & Conditions under Settings > Advocate Program > Advocate Consent, and ensure the toggle is set to 'on'. Advocates will see the Terms & Conditions after authenticating with their Identity Provider and must agree to them before accessing the AdvocateHub.
Does the AdvocateHub app support OAuth 2 for mobile access?
Yes, the AdvocateHub app provides a seamless login experience with OAuth 2, similar to desktop access, ensuring easy mobile entry for advocates.
