This article provides a step-by-step guide on how to edit or delete the schedule for queued and scheduled posts within a mobile application. It covers the process from accessing the 'My Shares' section to adjusting the queue times or captions, and offers support resources for users needing additional assistance.
Edit the scheduled queue time for each social network and tap 'Done', or delete the scheduled post by tapping on the 'X'. Once you have a post queued or scheduled, you may want to edit the caption, the time it's meant to be shared at, or cancel the post altogether.
Step 1: Tap 'My Shares' at the bottom of your screen
To begin, locate and tap on the 'My Shares' option which can be found at the bottom of your screen.
Step 2: Tap 'Queue' to see your queued and scheduled posts
To view your queued and scheduled posts, you can tap on the 'Queue' option. This will allow you to see the posts that are set to be published automatically according to your schedule.
Step 3: Edit Queue Time for a Post
Tap on a queued post for which you would like to edit the queue time. At this stage, you also have the option to edit the caption if desired.
Step 4: Edit the Scheduled Queue Time or Delete the Scheduled Post
Edit the scheduled queue time by scrolling to the bottom of the caption and clicking the edit pencil icon. Click on the date and time to adjust accordingly and then hit Save. Your queued post will be moved to its new queue time or will be removed from the queue if you choose to delete it.
Explore the following articles to learn more about using our platform:
- How to Share to Instagram via Android
- How To Suggest Content via the iOS Mobile App
How can I edit the caption of a scheduled post in the mobile app?
To edit the caption, tap on the queued post you wish to edit, and then you can modify the caption as desired.
What should I do if I want to change the time a post is scheduled to be shared?
Click on the edit pencil icon at the bottom of the caption, adjust the date and time accordingly, and then hit 'Save' to update the scheduled queue time.
Is it possible to delete a post that has been scheduled or queued in the app?
Yes, you can delete a scheduled post by tapping on the 'X' after selecting the post you want to remove from the queue.
Where can I find my queued and scheduled posts in the mobile app?
You can find your queued and scheduled posts by tapping 'My Shares' at the bottom of your screen and then selecting the 'Queue' option.
Who can I contact if I need help with scheduling or editing my posts in the app?
For any assistance, you can reach out to support at support@postbeyond.com.
