The article provides guidance on the recommended image sizes and ratios for posting on various social media platforms to ensure proper display in the Content Library. It suggests a universal resolution of 1100 x 550 pixels for posts across all networks, with a maximum image file size of 4 megabytes, and highlights the importance of using a 2:1 ratio for LinkedIn and Facebook to avoid image cropping on desktop views. For Instagram, the ratio is more flexible due to the platform's photo resizing feature.
Optimal Image Ratio & Resolution for a Post
Learn what the optimal image ratios and resolutions for a post are to ensure your images display correctly in the Content Library.
When creating a new post, it's important to consider the size of the image you upload and how it will appear in the Content Library.
Resolution
If you create posts to accommodate all networks, we recommend 1100 x 550 pixels. The maximum file size our platform supports for images is 4 megabytes.
Below are the optimal suggestions for image sizing for each social network, but not absolutely necessary:
- Shared Image: 1,200 x 630
- Shared Link: 1,200 x 628
- 440 x 220 pixels (a 2:1 ratio)
- Maximum to appear expanded 1024 x 512 pixels
- Stories: 1080 x 1920
- Shared Image or Link: 1104 x 736
Ratio
To prevent your image from being cut off on desktop for LinkedIn and Facebook, it's recommended to use an image with a 2:1 ratio, where the width is double the height.
Instagram Image Ratio
For Instagram, the image ratio is less critical as users can resize photos within their account.
What is the recommended image resolution for posts that accommodate all social networks?
The recommended image resolution for posts that accommodate all social networks is 1100 x 550 pixels.
What is the maximum image file size supported by the platform?
The maximum image file size supported by the platform is 4 megabytes.
What image ratio is recommended to prevent images from being cut off on desktop for LinkedIn and Facebook?
A 2:1 ratio, where the width is double the height, is recommended for LinkedIn and Facebook to prevent images from being cut off on desktop.
Is the image ratio critical for Instagram posts?
No, the image ratio for Instagram posts is less critical as users can resize photos within their account.
Who can I contact if I have questions about image sizing for posts?
You can contact support@postbeyond.com for assistance with questions about image sizing for posts.
