The article provides a step-by-step guide on uploading videos to Twitter through the PostBeyond platform, emphasizing the specific video requirements such as maximum file size, length, and format. It also offers troubleshooting tips, like contacting support for bugs and editing thumbnails, and details the process of creating and scheduling video posts for optimal visibility on user feeds.
Let's delve into how to upload videos to PostBeyond for Twitter posts. Below are the details on the specific video file requirements for Twitter.
How to Upload Videos for Twitter Posts
On the Administrator side of the platform, click on Posts then click on Video Library.
Click on Upload in the top right-hand corner of your Video Library.
Upload the video you would like to create posts with, ensuring it aligns with the video requirements for Twitter (max file size 512MB, no longer than 140 seconds).
Wait until your video is uploaded (this won't take long). Make sure you don't close this window until your video is fully uploaded.
Your video is now processing! Name the video so you can find it in your Video Library later. Feel free to leave the page at this point. We will send you an email once your video is ready for use.
Once your video is processed and ready for use, you will receive this email. Now you can create posts with your video!
Click the Create a Post button in the email or find your video in the Video Library and choose the dropdown option Create post.
NOTE: If you're not happy with the thumbnail of your video, you can edit the first frame and re-upload. Learn more here.
Time to create your video post! We have pre-selected the networks that you can share your videos to (according to network specific video requirements). Add your post title (this is internal only) and write your captions. Read more about creating network specific captions here.
Select the Topic(s) you'd like your post to be housed under. Add a Mandatory hashtag (optional). Select the Groups you would like the content to be visible to.
Set a start and end date (optional). Here you can toggle.
Click Save.
Here's what your video post will look like to your end users in their Feeds.
Here's what your video post will look like once it's shared out to Twitter.
Advanced:
- Length: 0.5 seconds - 140 seconds
- Frame rate: 60 FPS (Recommended 30 FPS)
- Dimensions: 32x32 - 1280x1024
- Recommended file size: 512 MB
- Aspect ratio: 1:3 - 3:1
- Pixel aspect ratio: 1:1
- Bit rate: 25 MBPS
- Only YUV 4:2:0 pixel format is supported
- Audio must be AAC with Low Complexity profile, High-Efficiency AAC is not supported
- Audio must be mono or stereo, not 5.1 or greater
- Must not have open GOP
- Must use progressive scan
What are the video file requirements for uploading to Twitter via PostBeyond?
Videos must be a maximum file size of 512MB, no longer than 140 seconds, with a frame rate of 60 FPS (30 FPS recommended), dimensions between 32x32 and 1280x1024, an aspect ratio from 1:3 to 3:1, and audio in AAC mono or stereo format.
How do I upload a video to PostBeyond for use in a Twitter post?
On the PostBeyond platform, navigate to 'Posts', then 'Video Library', and click 'Upload'. Ensure the video meets Twitter's requirements, wait for the upload and processing to complete, and you'll receive an email when it's ready to be used in a post.
Can I edit the thumbnail of my video after uploading it to PostBeyond?
Yes, if you're not satisfied with the video's thumbnail, you can edit the first frame of the video and re-upload it to PostBeyond.
