This article provides a step-by-step guide on how to delete a video file from your video library on PostBeyond. It also explains the difference between deleting a video file and a video post, and how to archive a video post.
To delete a video file, navigate to Posts > Video Library. Locate the video you wish to delete, click on the dropdown arrow next to it, and select Delete.
You will be prompted to type 'DELETE' to confirm the action. After confirmation, the video file will be removed from your PostBeyond Video Library.
For more information on managing space in your video library, please read the article here. Note that deleting video files does not delete the posts created with those videos.
To archive a video post, go to the Posts tab, find the post you want to archive, click the settings gear icon, and then select Archive.
What is the difference between deleting a video file and a video post?
Deleting a video file removes it from your Video Library on PostBeyond, but it does not delete any posts that have been created using that video. To remove a video post, you need to archive it separately.
Will deleting a video file from my library affect the posts made with that video?
No, deleting a video file from your library will not affect the posts made with that video. Those posts will remain active unless you choose to archive them.
