This article guides readers through the process of identifying and sourcing an RSS feed for a webpage, including what an RSS feed URL typically looks like and the steps to find one by viewing the page source and searching for 'rss' or 'feed'. If the RSS feed is not readily apparent, the article suggests contacting the website's developers for assistance and provides instructions on how to add the RSS feed URL to the reader's Inbox.
What Does an RSS Feed Look Like?
RSS feed URLs will usually contain an identifier of 'rss' or 'feed' of some sort in the URL itself.
Examples:
If you are looking at a URL and it does not have one of these words in it - it's probably not an RSS feed. BUT that's OK! You can still find it for that URL.
How to Find the RSS Feed
On a website page, you can find the feed by right-clicking the page and selecting 'View Page Source':
This will open up to a page of code:
To find the RSS feed, use Ctrl+F (Windows, Linux) or command+F (Mac) and type in 'feed' or 'RSS':
The URL that you find will be the feed. Please create your RSS feed in your Inbox with this URL.
Should you not be able to find this, please speak with the developers of the website, if it is a company page. They will be able to help you source this information.
Once you have your RSS feed URL, you can add it as a content feed in your Inbox.
- How to set-up RSS, Twitter, and YouTube feed
- Flow Chart: Differences Between Content Visibility and Newsletters
- How to Remove Inbox Feeds & Why Inbox Feeds Disappear
What is an RSS feed?
An RSS feed is a type of web feed that allows users and applications to access updates to online content in a standardized, computer-readable format.
How can I identify an RSS feed URL?
An RSS feed URL typically contains the word 'rss' or 'feed' within it. If these identifiers are not in the URL, it may not be an RSS feed.
What should I do if I can't find the RSS feed on a website?
If you're unable to locate an RSS feed, you should contact the developers of the website, especially if it's a company page, as they can provide you with the necessary information.
How do I add an RSS feed to my Inbox?
Once you have the RSS feed URL, you can add it to your Inbox as a content feed, typically by entering the URL in the appropriate section of your Inbox's settings or preferences.
