This article provides a step-by-step guide on configuring the PFL integration within your AdvocateHub. It includes instructions for authentication, settings configuration, and reward fulfillment using the PFL integration.
Follow these steps to configure the PFL integration and understand how to use it for reward fulfillment in your AdvocateHub.
The video above provides a visual walkthrough of the configuration process. The following steps outline the key actions required to set up the PFL integration.
Step 1: Access Integrations Library
Navigate to your Integrations library to begin the setup process.
Step 2: Manage PFL Integration
Click Manage on the PFL Integrations card.
Step 3: Authenticate Account
In the Setup Tab, click the authenticate button and enter your PFL account credentials.
Step 4: Configure Settings
Adjust settings in the Settings tab, such as enabling printing and selecting default stores, and save your changes.
Step 5: Review Logs
Check the logs to monitor the transfer of rewards between your AdvocateHub and the PFL integration, noting any successes or failures.
Using the PFL Integration
To use the integration for reward fulfillment, select the appropriate options in the fulfillment category when adding a new reward.
What is PFL integration in AdvocateHub?
PFL integration allows AdvocateHub users to manage and fulfill printing rewards directly through their PFL account.
How do I authenticate my PFL account in AdvocateHub?
In the PFL integration setup tab, click the authenticate button and enter your PFL email and password to link your account.
How can I check if the rewards are successfully transferred to PFL?
You can review the logs in the PFL integration to see the status of each reward transfer, including successes and failures.
