This article provides instructions on how to configure the default point structure for your program's hub. It includes steps for setting point values for member activities and notes on how these changes apply to challenges and stages within the hub.
To set the default point structure for your hub, follow the steps outlined below. This will help you to align member activities with the appropriate point values, ensuring a consistent scoring system across your program.
Navigating to Default Point Structure Settings
To set the default point structure for your hub, navigate to Settings > Scoring & Achievements > Default Point Structure.
Setting Default Point Values
Here you’ll be able to set the default point values you would like to associate with key member activities such as uploading an image, sharing a link, or providing a Net Promoter Score (NPS).
To adjust point values, simply adjust the sliders until your desired point values show in the ‘Default Points’ column and click ‘Save Changes’.
Applying Point Values to Challenges
Next time you go to create a Challenge when you select a stage that has a point value assigned to it under the ‘Default Point Structure’, it will auto-populate with the point value you have set. You can opt to change the points for individual Challenges as required.
Note: The point structure changes will not retroactively modify the points for existing Challenges/Stages. It only applies to new Stages going forward.
How do I set the default point structure for my program's hub?
Navigate to Settings > Scoring & Achievements > Default Point Structure to set the default point values for member activities.
Will changes to the point structure affect existing Challenges or Stages?
No, changes to the point structure will not retroactively modify the points for existing Challenges/Stages. It only applies to new Stages going forward.
Can I change the point values for individual Challenges?
Yes, you can change the points for individual Challenges as required, even after setting the default point structure.
