The article provides a step-by-step guide on how to configure the visibility of rewards to specific audiences within an Influitive hub. It explains how to access and edit reward eligibility, set targeting options for inclusion and exclusion of members, and utilize advocate filter criteria such as individual identification, group membership, advocate information, behavior, and responses to questions.
Targeting options in rewards allow you to choose who should and shouldn't see your reward. This is great for segmenting rewards based on status, region or other factors. As with groups and challenges, each reward has an Eligibility option, where you can limit who has access to a reward. Here's how to set it all up:
Step 1
While on your Rewards page, click on an active reward you have created on your Influitive hub. You will be directed to the page for that reward (below). Select Edit.
Step 2
From the Edit page, click on the Eligibility tab.
Step 3
On the Eligibility screen you will see the screen below, which features all of your targeting options. This is similar to targeting for Challenges . This allows you to control if a reward is available to nominees or advocates, and also to further segment based on other criteria.
The first section is for the inclusion of members. The first option in this area is Everyone . When selected, everyone in your hub will see this reward. This is useful for the cases when you want to include every advocate except a few people or a specific group of people.
If you would like advocates who match specific criteria to see this reward, add rules under the button: Include advocates that meet all/any of the following .
The second section is for the exclusion of members. The first option in this area is No One . If you don't want to prevent anyone from seeing the reward you can leave this as is.
If you would like advocates be excluded from this reward, add rules under the button: Exclude advocates that meet all/any of the following .
You will also note the option to include (and exclude) members who meet all or any of the conditions you choose from the dropdown menu.
Filter types
Below are the filters available to include or exclude your advocates with the criteria you're looking for.
- Individuals : Specific advocates.
- Group : The advocate is a member of a specific group
- Advocate Info : Criteria based on information about the advocate (e.g. Industry, Region, Title, etc.)
- Behaviour : How the advocate behaves in your hub (e.g. Engaged, Not Engaged, completed specific challenges, etc)
- Responses : Includes/Excludes advocates based on their response to a question. You can choose to segment an exact response or a response which contains a certain word.
How do I access the reward I want to edit for targeting and visibility?
Navigate to your Rewards page, click on an active reward, and then click Edit to modify the reward's visibility settings.
What are the targeting options available for setting reward visibility?
You can include or exclude members based on individual identification, group membership, advocate information (e.g., industry, region, title), behavior (e.g., engagement level, challenge completion), and responses to questions.
Can I set conditions for reward visibility to target specific advocates?
Yes, you can add rules to include or exclude advocates based on specific criteria and decide whether members should meet all or any of the conditions to be included or excluded.
What is the default setting for excluding members from seeing a reward?
The default exclusion setting is "No One," which means no one is prevented from seeing the reward unless specific exclusion rules are added.
Where can I find information on scheduling my reward and setting its redemption options?
For information on scheduling your reward and setting its redemption options, you can click the provided link in the article after saving your visibility settings.
