The article provides a comprehensive guide for administrators on how to effectively manage the advocates list within an admin view. It covers customization of display columns, filtering advocates for specific data, saving and sharing customized views, exporting advocate data in various formats, and performing bulk actions such as messaging, locking accounts, rewarding, and logging activities. The article emphasizes the importance of understanding these functionalities to streamline the management process and enhance productivity.
- Managing columns on the advocates list
- Filtering the advocates list
- Saving and sharing views of the advocates list
- Exporting advocate data
- Performing bulk actions on advocates
By clicking on the Columns button on the Advocates tab in Admin View, you will be able to choose from a number of options, including Advocate Details, Custom Profile Fields, CRM / marketing automation IDs, and even responses to a challenge question.
Whatever you choose, the values for that choice will be added to the advocate list. If you'd like to clear your choices and start from the default state, simply click the Columns button again and click the "Reset" link next to the "Active Columns" heading.
In addition to adding columns, you have many options for filtering your advocates list. This feature is valuable if you are looking to look over, share or export information about a specific subset of advocates. Filters allow you to easily access information about advocates relevant to your current task.
At the top of the Advocates list, you will find the filters tab. The filters here will work the same way as the targeting in any challenge, group, channel, etc. For a more in depth description of how to use these filters, please refer to the Challenge Targeting Overview and Advocate Tab: Advanced Filtering article.
If you have create a view you'd like to save for re-use or for sharing with another administrator of your Hub, click on the link icon (pointed out below to generate a URL which, if pasted into the browser later, will populate the columns you have currently selected.
Step 1: Click the link button
Step 2: Copy and save the URL for later use
Note: This link will only work for people who have admin access to your Hub. To share your data with others who do not have access to the Hub, refer to the section below on exporting the advocate list.
Exporting the advocates list
If you have created a view of your advocates list using the columns and filters discussed above, you can export the current state to CSV and XLS files. To do so, click on the Actions button, and choose "Export All" (seen above).
Your export files will appear in the "Action Centre" of your toolbar (shown below) once the request has been processed.
Note: Wondering why your export is so small? Ensure that you have selected (or cleared) all of the filters to ensure they include all of the advocates you'd like to export. If you want to export everyone, ensure all filters are cleared.
Currently, the following actions can be performed on advocates in bulk / batches:
- Send a message
- Lock account
- Give reward
- Log activity
To perform your action, select the advocate(s) by checking the box beside their name and choosing the desired action under the Actions button.
Checking the box at the top of the advocates list (pointed out below) will select everyone on the current page only .
If you wish to select all pages of advocates, scroll to the bottom after you've checked the box above. You will find the option to select all of the advocates who meet the criteria of your filters (or every advocate if you have no filters).
Send a message
To send multiple advocates the same message, you can use the "send a message" bulk tool.
Lock account
To lock multiple advocate accounts at once, you can use this bulk-lock advocates function.
Give Reward
To bulk-award advocates a reward, you must first select which reward you'd like to give, then select the redemption method.
Log Activity Batch Action
The "Log Activity" action lets you record advocacy activity outside of the hub. For example, you may want to give points to your customers for attending an event or webinar, or log a customer referral that took place outside your AdvocateHub campaign.
After selecting this batch action, you can fill out the below modal with details about any offline advocacy activity.
- Activity Name* - The name of the activity you are tracking. Your advocates will see this activity on their profile feed.
- Date* - The date you'd like to record this event on.
- Advocacy Type* - Select which category this activity falls under.
- Channel - You can select an associated experience for your logged activity. Any points awarded in this case will be applied to the your channel leaderboard.
- Points - You have the option of awarding points to your advocates.
- Description - An internal description of the activity. Advocates do not see this.
How can I customize the columns displayed on the advocates list?
You can customize the columns by clicking on the "Columns" button in the Advocates tab, selecting the desired options like Advocate Details, Custom Profile Fields, and CRM IDs, and adding them to the list. To revert to default settings, click "Columns" and then "Reset" next to "Active Columns."
What should I do if my exported advocate data file is smaller than expected?
Check the filters you've applied to ensure you've selected or cleared all filters to include the desired range of advocates. To export the entire list, all filters should be cleared.
How do I save and share a customized view of the advocates list?
To save and share a view, click the link icon to generate a unique URL, then copy and share this URL. Note that this link will only work for individuals with admin access to your Hub.
Can I perform actions on all advocates across multiple pages at once?
Yes, to perform actions on all advocates across multiple pages, select the checkbox at the top of the list for the current page and then choose the option at the bottom of the page to select all advocates who meet your filtered criteria or all advocates if no filters are applied.
How do I send a message to multiple advocates simultaneously?
Use the "Send a Message" bulk action by selecting the desired advocates and then choosing "Send a Message" from the Actions dropdown menu to send the same message to multiple advocates at once.
