The article outlines a method for engaging advocates by creating a quiz stage within a platform, which serves both educational and engagement purposes. It explains the process of setting up the quiz, including how to target responses for challenges and rewards, and directs readers to additional resources for best practices.
Create a quiz for your advocates and automatically award points for all correct responses with zero administrative follow-up!
How it works
Use this stage to create a quiz for your advocates. You can use this for educational purposes or simply a fun way to engage with them.
To set up this stage:
- Create as many questions as you would like for the quiz
- For each question, you can configure multiple wrong answers and 1 correct answer, as well as points for every question.
- The options will be displayed as a radio button selection to advocates (see screenshot above).
- For every correct response, advocates will automatically be awarded points. There is no verification required on your end.
- For every wrong response, advocates will not be awarded points and the correct response will be shown.
Some caveats to watch out for
- Every challenge can only use the Quiz stage once .
- Advocates can only answer each questions once . This prevents anyone from taking advantage of earning points after learning the answers.
Quiz Response Targeting
You can target challenges, rewards, groups, etc., in the system based on answers to a Quiz stage question.
Quiz Answer options are included in the Responses filter in targeting. For more information on targeting, check our article on Targeting Challenges .
For other tips and best practices, check out the AdvocateHub Class on Quiz stage here .
What is the purpose of creating a quiz for advocates?
The purpose of creating a quiz for advocates is to educate them and to provide a fun and engaging tool that can enhance their involvement and interaction within the platform.
How can quiz responses be used in the system?
Quiz responses can be targeted for challenges, rewards, and groups within the system, allowing for personalized engagement and incentives based on the answers provided by the advocates.
Where can I find additional resources and best practices for setting up a quiz stage?
Additional resources and best practices can be found by checking out the AdvocateHub Class on Quiz stage, which is likely a resource provided by the same platform or service.
