This article provides guidance on how to manually advance advocates through different stages of a challenge within Influitive, particularly when activities are completed outside the automated tracking system.
Advocates may sometimes complete challenge-related activities externally and forget to mark them as completed. This section outlines the steps to manually advance advocates through challenge stages in Influitive.
Understanding Challenge Progress
To check the progress of advocates in a challenge, navigate to the Challenge page and select the In Progress tab.
If an advocate has completed a stage, such as a reference call, but has not marked it as completed, you can manually advance them to the next stage.
Manually Advancing an Advocate
From the In Progress tab, select "more options" and then "Advance to Stage 3 for Advocate" to manually advance the advocate.
This can also be done from the advocate's profile page under the Challenges tab.
For logging activities that are not part of challenges but deserve credit, such as leading a user group or hosting a webinar, refer to the following guide: Logging Activities for Advocates.
What is Influitive?
Influitive is a platform that allows companies to engage with their advocates, customers, or fans to encourage participation in challenges and activities that promote the brand.
How do I manually advance an advocate to the next challenge stage?
To manually advance an advocate, go to the In Progress tab under the Challenge page, select "more options" next to the advocate's name, and choose "Advance to Stage 3 for Advocate."
Can I credit advocates for activities not tracked in Influitive?
Yes, you can log activities for advocates that are not part of the challenges but are still valuable contributions. For instructions, click here.
