Start a conversation
Manually Awarding Badges to Advocates in Influitive
The customer asked, "how do I grant a specific badge to an advocate?" The issue was that while the system mentioned manual badge awarding, it did not provide specific instructions. The solution involved navigating to Admin Settings, locating the badge, accessing the advocate's profile, and manually awarding the badge. Manual awarding does not automatically allocate points or update reporting.
Issue: How to manually award a badge to an advocate
Resolution Steps:
  1. Access Admin Settings:
    • Navigate to the Admin Settings area of your Influitive Hub.
  2. Locate the Badge:
    • Go to the Levels & Badges tab.
    • Find the badge you wish to award. If it hasn't been created, add a new badge here.
  3. Award the Badge Manually:
    • Search for the advocate's profile in the Members section.
    • Within their profile, locate the Badges section.
    • Click the option to manually award a badge and select the desired badge.
    • Save your changes. The badge will now appear on the advocate’s profile.
Important Notes:
  • Manual badge awarding does not automatically allocate points or update reporting like automated rules.
  • Badges can be awarded retroactively to advocates who met criteria before the badge was created.
Additional Resources:
Frequently Asked Questions
How do I manually award a badge to an advocate?
Navigate to Admin Settings, locate the badge, go to the advocate's profile, and manually award the badge in the Badges section.
Does manual badge awarding allocate points automatically?
No, manual badge awarding does not automatically allocate points or update reporting. Automated rules are recommended for consistent tracking.
Can badges be awarded retroactively?
Yes, you can award badges retroactively to advocates who have already met the criteria before the badge was created.
Was this article helpful?
Yes
No
  1. Priyanka Bhotika
  2. Posted
