Kotis Design
Kotis is your hub for managing all projects – past and present. No more browsing catalogs, our curated showcases allow you to pick the swag that works for your business. Review and approve art proofs without the hassle, and when you’re ready to order, save time and do it from the same platform.
Here is an overview of the steps:
Sign up for a Kotis Design Account
If you are not already a Kotis Design customer, take a look at their offerings, and reach out to the Kotis Design team on their website:
https://go.kotisdesign.com/
Notify Influitive
Now you will need to contact Influitive Support (support@influitive.com) to enable the Integration from the back-end for your AdvocateHub. Influitive will need your Kotis Design API key which you should be able to obtain from Kotis Design.
Once we have completed this step, the two systems should be connected and ready to go and all that is left to do is to build out the Influitive rewards.
Configuring Kotis Design Rewards In Influitive
1. The first checkbox you will see on the
Fulfillment tab indicates whether you would like this process to be fully automated or you would like to manually approve the redemption.
If the box is checked it means you will need to approve the redemption when someone requests the reward. To do this you can click the green
Approve Without Fulfilling button under the
Rewards section of the
Items To Review area of your Admin Dashboard.
If this box is not checked, the redemption will be automatically sent to Kotis Design and fulfilled in Influitive so there is no action required.
- Also on the Fulfillment tab of the reward creation page, you need to choose the 'Manual' radio button:
3. On the
Headline tab of the reward creation page, scroll down to the 'Auto Fulfillment Data' section and enter "Kotis" in the
Provider field and your Kotis Design SKU/Item ID in the
Sku field. You are free to fill out the rest of the field on this page however you like:
4. On the
Redeeming tab of the reward creation page, scroll all the way to the bottom and ensure the Shipping Information checkbox is enabled:
5. You can ignore this section if the item is just a mug or some other non-wearable item that will not have a size associated with it but if there is a size you need to ask them what size they want and give them the potential answers in a dropdown as shown below - this data must be
exact. For example, writing ‘Small’ instead of ‘S’ won't work as that is not the format that Kotis uses.
How It Works
Now that everything is set up you are ready to go! When an Advocate requests a reward in Influitive we will check with Kotis Design to make sure the item requested is in stock. If it is not in stock we will decline the redemption with a note explaining why and the Advocate points will be returned. If there is stock, we continue to create the order with Kotis Design.
We will then mark the redemption as ‘fulfilled’, closing the loop. If the order is canceled in Kotis Design at any time after this point then the Admin will need to manually give the points back to the Advocate.
Remember, if you have checked the checkbox that says 'Administrator Approval Required' then you will need to automatically approve the redemptions before we create an order with Kotis Design. If this box is not checked then everything will be fully automated.
