Salesforce Lightning: Installing AppExchange Package for the first time
The new AdvocateHub Salesforce AppExchange App is here! If you:
- are using Salesforce Lightning version AND
- have never installed any Influitive-Salesforce AppExchange package
Then this is the instruction article for you
This AppExchange Package is the newest and latest version (Version 3.5) and it includes the following items:
- Compatibility with Salesforce Lightning and Salesforce Classic
- Improved Nomination button tool and MultiHub support
- Improved Reference Request tool and MultiHub support
- New Acts of Advocacy Object and MultiHub support
- New Salesforce Dashboard Reports
- Consistent labels and naming for the components
Installing the Influitive AppExchange Package 3.529
AppExchange Package Link
Select Install for All Users and click Install or Upgrade.
- Once Installation is completed, you will see the completion message or email. Login to your Salesforce to check if the package version (Setup > Platform Tools > Installed Packages > Package Name: AdvocateHub > Version Number 3.+).
Notes:
- To enter your credentials, navigate to the Setup Tab and click Authenticate to start and you will see the following page. Choose the Auth Method: Standard vs OAuth 2.
- Next, enter the Username, Password, Token and Organization ID associated with your Salesforce account. Please make sure the Organization ID is correct and that the connected integration user has the following Salesforce: Required Field Permissions:
- How to find your Token: Go to Settings on Salesforce under your Admin avatar > Reset My Security Token > Click on the Reset Security Token button. You will be sent an email to your inbox containing the token.
- How to find your Organization ID: To find Organization ID, go to Salesforce Setup > In the Quick Find Search, type Company Information.
- How to connect without a token:
- Login to Salesforce and go to Setup > Security > Network Access.
- Under App Exchange Version, please select version 3.5. Once all the data is confirmed, please hit Save to authenticate the integration.
Influitive Hub Mappings
Next, you will need to add Hub Mappings to connect the Hub.
Hub Mappings Menu
- Once logged in to your Salesforce, head over to any Contacts Page. Or go to the App Launcher > Search > Hub Mappings.
- Click on the pencil icon on the navigation menu to "Personalize your nav bar"
- In the Edit Sales App Navigation Items > click Add More Items
- Then Search for Hub Mappings > Click on the Plus sign > click Add Nav Items
- The Influitive Hub Mappings Menu is now on your Navigation menu.
Add AdvocateHub to Influitive Hub Mapping
- Once the menu is added, click on the Hub Mappings menu from the Navigation tab
- Click on the New button
- Enter your Influitive Hub Program Name under Program Name field. This is so that each Advocacy event can be identified by which Hub it occurred in.
- For Hub ID, this information is available on your AdvocateHub. Sign in to your admin account in the AdvocateHub > Click on the gear icon > Integrations > Influtive API > Manage > Click the Setup Tab > Copy the number string from X_ORG_ID.
- Paste in on the Influitive Hub Mapping under Influitive Hub ID field and click Save.
Influitive Hub Mapping Name: Please enter the Name of your Hub Program
Influitive Hub ID: The X ORG ID Number provided in Influitive API
Influitive Hub Domain: Please enter the URL of the Advocatehub (e.g. https://hub.influitive.com) -
- For Multiple Hubs, you will need to add all the Hub Mappings for each Hub. More on MultiHub CRM Setup.
Adding Components in the Page Layouts
After installing and deploying the AppExchange package, the Salesforce administrator will need to modify a few object layouts to add the Influitive integration components.
Page Layout Changes Checklist:
Contacts Layout:
- Add Contacts Converted Details (Visualforce Page)
- Add Date Joined and Date Added to AdvocateHub fields
- Add Influitive Acts of Advocacy Component (Related List)
- Add Reference Received via Influitive
Accounts Layout:
Leads Layout:
- Add the following fields: Referral ID, Influitive Referral Source, Referrer Company, Contact, Email, Name
Opportunity Layout:
- Add Referral ID field (Only if you're planning to convert Referral Lead to an Opportunity record)
- Add the Reference Request tool
Contacts Page Layout
To start, go to Contacts > Select a contact record > Click on the Gear icon > Edit Page. The following components are provided from the AppExchange Package:
Contacts Converted Details / Nominate Button
This widget will outline the Contact details in the Hub (e.g. email, Current Points, Lifetime Points, Level, Nominated By).
Select ContactDetailComponent and drag and drop it on the page. (Anywhere you like).
- Once you're happy with the location, click Save to save the layout.
Here's what the component should look like if the contact is added to the Hub:
Here's what the component should look like if the contact has not been added to the Hub:
Please note that if you have 1.12 or 1.15 version previously installed, you will need to remove the old Nominate button component. The Converted Contact Details will replace this component.
Date Joined AdvocateHub and Date Added To AdvocateHub
These fields will auto-update whenever the contact is added or joined the AdvocateHub.
Please note that if you have multiple Hubs and looking to integrate with Salesforce, you may skip adding these two fields. The replacement component will be noted in the Salesforce: MultiHub CRM Setup article.
- Go to Object Manager > Contacts > Page Layout > Click the Layout that will be used
Select Fields > Drag Date Joined AdvocateHub and Date Added To AdvocateHub fields to the area that you prefer.
- Click Save to save the changes to the Layout.
Influitive Acts of Advocacy Object
- On the same page > Select Related Lists > Drag and drop Influitive Acts of Advocacy to the area that you prefer.
- Once added, click on the wrench icon on the component. In this window, please add the following fields to display in the Influtive Acts of Advocacy Object. Click OK once you're done.
- Advocacy Type - https://support.influitive.com/article/619-acts-of-advocacy-types-and-reporting-category
- Prospect - If you are using the Reference request tool, this column will show the prospect's name that the contact completed a reference for from the Hub. If you are not using the Reference Request tool, you may skip adding this field column.
- Once saved, try and search for a Contact record > Click the gear icon > Edit Page
- Click on the Related List area where you've placed the Acts of Advocacy Component > On the right-hand side of the screen, under Related List Type > Enhanced List. This will display the columns that you've selected. Click Save once you're done.
- Once done, it should look like this:
Please note that if you have 1.12 or 1.15 version previously installed, you will need to remove the old Advocacy Activities component. The Acts of Advocacy will replace this component.
References Received via Influitive Object
- In the same page > Select Related Lists > Drag and drop References Received via Influitive to the area that you prefer.
- Once added, click on the wrench icon on the References Received via Influitive component.
Please note that if you have 1.12 or 1.15 version previously installed, you will need to remove the old Advocacy Activities (Prospect) component. The References Given will replace this component.
Accounts Page Layout
To start, go to Object Manager > Accounts > Page Layout > Click the Layout that your Salesforce users use. The following components are provided from the AppExchange Package:
- Select Related Lists > Drag and drop Influitive Acts of Advocacy to the area that you prefer.
- Once added, click on the wrench icon on the Acts of Advocacy.
- Click OK and click Save to save the changes to the Layout.
- Once saved, try and search for an Account record > Click the gear icon > Edit Page
- Once set, it should look like this:
Head over to the Lightning App Builder and drag and drop "ReferencesRelatedListCmp" over to the layout and Save the page
Leads Page Layout
To start, go to Object Manager > Leads > Page Layout > Click the Layout that your Salesforce users use. The following components are provided from the AppExchange Package:
- Under Fields > Drag and drop the following fields to the preferred area of the layout
- Referral ID (appexchange) - Required
- Influitve Referral Source - Recommended
- Referrer Company, Contact, Email, Name - Optional
Opportunity Page Layout
To start, go to Object Manager > Opportunity > Page Layout > Click the Layout that your Salesforce users use. The following components are provided from the AppExchange Package:
- You are required to add this field if your Referral Lead from Influitive Hub in Salesforce converts into an Opportunity.
- Under the Fields > Drag and drop Referral ID (appexchange) field to the appropriate area of the layout.
This custom object will list all the reference activities for the Opportunity.
- Go to the Related List > Drag and drop References Received via Influitive
Click on the wrench icon > Add the following fields:
- Advocacy Type
- Act of Advocacy Name
- Channel
- Contact
- Content
- Date Occurred
- Prospect
- Source Title
- Requested By
Reference Request Tool
Note: This tool is used to create reference requests challenges in the AdvocateHub. The Request a Reference component should only be added to the Opportunity object. It will not work on any other Salesforce object type. This Reference Request feature may be an additional cost, please contact your CSM to confirm.
- Go to the Opportunities tab and select an Opportunity record.
Click on the Gear and select Edit Page option.
Create a new tab for Request a Reference
Search for the Custom - Managed menu on the left-hand side and drag and drop RequestReferenceComponent to the tab you have just created.
Click Save. You may need to wait a few minutes for the Preview to load. Once loaded, check the Opportunity Record to see the changes you've made.
- All done! To see the Hub members and Reference requestor experience on using the Reference Request Feature as well as the best practice for this feature, please follow the following article - Salesforce: Reference Request
If you like to add the Reference Request tool as a button in Salesforce, please see this article: How to add Reference Request Converted as a button in Salesforce.
Salesforce-Influitive Individual Feature Setup
Great! The Salesforce instance is now ready to be populated with content from Influitive Hub. Please continue the setup on the Influitive Integration by going through the following articles for the Salesforce integration features that you're looking to enable in the Hub.
