Single Sign-On Type
By default Single Sign-On allows any user with access to the Identity Provider (IdP) to gain access to your AdvocateHub. Any 'gating' or any restrictions on the user's access to the AdvocatHub application would need to be done on the Identity Provider side. This new feature allows you to easily control and puts restrictions in place directly from your AdvocateHub.
This article will cover the three options we provide below:
- Open Signup
- Invite Only
- Request Access
Once enabled, you will see the options in the screenshot below on the same page where you configure your Single Sign-On configuration: Settings > System > Login/Security:
Open Signup
This setting is much the same as what we use by default. The user will have access to your AdvocateHub as long as they have access to your IdP.
The potential flows will be as follows:
Flow #1 - User not logged into the IdP in their current browser session
- The user navigates to AdvocateHub URL
- The user is directed to IdP login screen
- The user enters credentials successfully
- The user is directed back to AdvocateHub where they will be now logged in if they already have an account matching the same email address they use to login to the IdP or an account will be created for them if one does not already exist.
Flow #2 - User already logged into the IdP in their current browser session
- The user is now logged in to AdvocateHub if they already have an account matching the same email address they use to login to the IdP or an account will be created for them if one does not already exist.
Invite Only
This setting is designed to ensure that only members who have received an email invite or are using a Join URL to signup to your AdvocateHub are allowed access regardless of whether they have access to your IdP. When using OAuth, they can not use Join URL's only email invite links.
Flow #1 - User attempts to signup to your AdvocateHub but has not been invited or received a Join URL
The user navigates to the AdvocateHub URL and once they are authenticated with the IdP they will see the below message and be unable to access the AdvocateHub:
Flow #2 - User attempts to signup to your AdvocateHub via an invite link or a Join URL
Once the are authenticated with the IdP and attempt to access the AdvocateHub, they will gain access.
Note: This message or page is not customizable
Request Access
This setting is similar to the 'Invite Only' one with the difference being instead of the user being greeted a message stating that it is an 'invite-only' community a 'Join Request' will be created which the Admin can then approve or decline.
Once they click Request Access they will receive confirmation of the request:
Note: At this point, an account will be created for the user in the system and you will find them under the 'Invite List' in your hub.
The Administrator of the program will now see the request under the 'Items To Review' section of the Admin Dashboard:
When the Admin clicks 'Review', they will be given the option to Approve or Decline Request. If approved, an invite will be sent to the user right away. If declined, the user remains in your 'Invite List' to be invited at a later date if you wish but no other action occurs at this time.
Note: If an advocate is already a member of another AdvocateHub with the same email address then there is one additional step in both flows. After they successfully enter their credentials into the customer portal, they will see a message like below:
An email will be sent to the Advocate which will include a link which they just have to click on and they will be brought back to the login screen to enter their credentials once more before gaining access to the AdvocateHub.
