The article provides a guide for administrators on how to track leads generated by PostBeyond using Adobe Analytics and c_id codes. It explains the integration feature, which is currently in beta, and the process of using CID codes as query-string parameters to measure the impact of PostBeyond programs. The article also mentions the availability of different URL addition versions for tracking and encourages reaching out for detailed explanations or further assistance.
Learn how to track leads generated by PostBeyond with Adobe Analytics using c_id codes.
DISCLAIMER: This is a beta feature that is currently being tested.
What is Adobe Analytics on PostBeyond?
The Adobe Analytics feature is for all admins whose companies use Adobe Analytics for tracking website traffic.
This feature allows you to measure the impact of your PostBeyond program using CID codes as query-string parameters.
How it Works
The CID value would display like so:
Things to Consider
PostBeyond would be the CID value and how you'd filter any reports in Adobe.
The post title would look like the example above (highlighted in Blue).
We currently do not have the ability to create post title as a value in our current version of the Adobe Analytics integration.
CID Codes + PostBeyond
Every post shared from PostBeyond automatically has Adobe CID tracking codes. These codes help Adobe identify where the traffic is coming from.
As shown in the figure above, the CID tracking codes are instrumental in tracking the source of web traffic.
Adobe CID Set Up
There are three different versions of URL additions that can be selected to enable tracking.
For a detailed explanation of how each version differs from one another, reach out to your CSM or support.
Helpful Analytics Resources
Explore the following resources to better understand the analytics features and how to utilize them effectively:
- What are the Different Analytics Pages?
- How to Use Google Analytics for PostBeyond
- How to Track Your Success Through PostBeyond
What is the purpose of the Adobe Analytics feature on PostBeyond?
The Adobe Analytics feature on PostBeyond allows administrators to measure the impact of their PostBeyond program using c_id codes as query-string parameters to track website traffic.
How are c_id codes used in PostBeyond?
c_id codes are automatically attached to every post shared from PostBeyond, which helps Adobe Analytics identify the source of web traffic and track leads.
Is the Adobe Analytics integration with PostBeyond fully available?
No, the Adobe Analytics integration with PostBeyond is a beta feature currently being tested. Interested parties should contact their Customer Success Manager (CSM) or support@postbeyond.com to participate in the test.
How can I set up Adobe CID tracking with PostBeyond?
There are three different versions of URL additions that can be selected to enable Adobe CID tracking with PostBeyond. For a detailed explanation of each version, you should contact your CSM or support.
Who should I contact if I need assistance with Adobe Analytics on PostBeyond?
If you need assistance with Adobe Analytics on PostBeyond, you can contact support at support@postbeyond.com.
