This article provides a step-by-step guide on how to unarchive and retrieve a post that has been previously archived from the content library. It details the process from selecting the 'Posts' option in the menu to republishing the content by clicking 'Save', thereby making it active and visible again in the Administrator view.
Learn how to unarchive a post. Read the following steps to learn how to unarchive/retrieve a post that has been archived/removed from the content library.
Step 1: Select 'Posts'
To begin, select the 'Posts' option from the menu. This will allow you to manage and create new blog posts or articles for your website.
Step 2: Select 'Archived'
In this step, you will need to select the 'Archived' option. This action is typically necessary when you want to view or manage items that are no longer actively in use but have been preserved for record-keeping or compliance purposes.
Step 3: Select 'Edit' over the Gear Icon
To modify settings, click on the 'Edit' option which is found above the gear icon.
Step 4: Select 'Save' to Publish
After completing the necessary steps, click the 'Save' button to publish your content. This action will make your post active in the content library and visible under 'Posts' in the Administrator view of the platform.
Explore the following resources to assist you with common tasks:
- How to Archive a Post
- How to Create a New Post Manually
- Where Can I Find Archived and Pending Posts?
How do I start the process of unarchiving a post?
Begin by selecting the 'Posts' option from the menu to manage and create new blog posts or articles for your website.
Where can I find the posts that have been archived?
You can find your archived posts by selecting the 'Archived' option, which is for viewing or managing items that are no longer actively in use but have been preserved.
What should I do to make an archived post active again?
To make an archived post active again, select 'Edit' above the gear icon, make any necessary changes, and then click 'Save' to publish the content.
Who can I contact if I need further assistance with unarchiving a post?
If you require further assistance, you can reach out for support at support@postbeyond.com.
