This article provides a comprehensive guide on setting up Mandatory Hashtags, which are essential for ensuring compliance, unifying social campaigns, and reinforcing branding on social media. It distinguishes between Global Mandatory Hashtags and regular Mandatory Hashtags, detailing the process for enabling them both instance-wide and on a post-by-post basis, and explains their appearance and function in user posts, with a note that they are not visible on mobile when sharing.
Learn how to set up mandatory hashtags. In this article, we will go over how to set up Mandatory Hashtags - hashtags that will automatically be applied to posts users share.
We will specifically go over:
- What are Mandatory Hashtags and why use them?
- How to enable Mandatory hashtags?
- How do they work when a user shares?
- How Mandatory Hashtags will appear in other sections of the end-use view
*IMPORTANT*
Mandatory hashtags will not be visible to users sharing from mobile.
What are Mandatory Hashtags and Why Use Them?
Mandatory Hashtags are hashtags that are required for posts and must be used by users. They serve various purposes, including compliance with regulations, unifying social campaigns, and branding.
Global Mandatory Hashtags vs. Mandatory Hashtags
There are two types of mandatory hashtags. Global mandatory hashtags are limited to one per instance, and the admin can choose to make this hashtag unchangeable during the post creation process.
On the other hand, mandatory hashtags can be modified during the post creation process. Admins have the option to add up to four mandatory hashtags at this stage.
How to Enable Mandatory Hashtags
PART 1: Enabling the Hashtag Instance-wide
In the admin panel, navigate to the Settings > Company tab:
You will be presented with a page similar to the one below:
Enter the Global Mandatory Hashtag. Remember that currently, only one can be registered.
You also have the option of enabling the Global Mandatory Hashtag by default and making it unchangeable in the post creation view.
PART 2: Enabling Mandatory Hashtags on a Post-by-Post Basis
Depending on the configuration of the option toggles above, you and your admins can enable or disable mandatory hashtags on a post-by-post basis.
As the admin, you have the option to add up to four mandatory hashtags or simply publish the post with the Global Mandatory Hashtag.
How do they work?
Once enabled, the users will see this messaging in their posts before sharing content as such:
As mentioned, this is mandatory - so users will not be able to remove this hashtag.
Once shared, the post will appear on social media similar to how posts would normally be depicted. Note: the hashtag will only appear at the end of the body of the message:
Editing a Queued Post
Content Card Preview
Below are links to articles that provide guidance on managing various settings and features within our service:
What are Mandatory Hashtags?
Mandatory Hashtags are required hashtags that must be included in posts by users, often used for compliance, unifying social campaigns, and branding purposes.
What is the difference between Global Mandatory Hashtags and regular Mandatory Hashtags?
Global Mandatory Hashtags are limited to one per instance and can be made unchangeable during the post creation process, while regular Mandatory Hashtags can be modified during post creation, with admins able to add up to four.
How do I enable a Global Mandatory Hashtag?
To enable a Global Mandatory Hashtag, navigate to the Settings > Company tab in the admin panel, enter the hashtag, and choose whether it should be enabled by default and unchangeable in the post creation view.
Can users remove Mandatory Hashtags from their posts?
No, once Mandatory Hashtags are enabled, they are required and users will not be able to remove them from their posts.
Are Mandatory Hashtags visible to users sharing from mobile devices?
No, Mandatory Hashtags will not be visible to users sharing posts from mobile devices.
