The article explains why users might encounter only one post within a Topic they are following. It clarifies that the scarcity of posts is due to the Admin or Content Creator not adding more content to that Topic. Users are guided to check the number of posts in a Topic through the 'Manage Topics' section.
Occasionally you might notice that a Topic you have followed only has one post listed under it. This is because the Admin or Content Creator has not added more posts under that Topic.
You can find out how many posts are listed under any Topic by going to 'Manage Topics' under Topics.
Here you can find out how many posts are available in each Topic that you are currently following. The Topic 'Events and Webinars' here has only one post listed, which is why the Feed is only showing one post.
Why is there only one post in a Topic I am following?
There is only one post because the Admin or Content Creator has not added more posts to that Topic.
How can I check how many posts are in a Topic?
You can check the number of posts by going to 'Manage Topics' under Topics in your account.
What should I do if I want more posts in a Topic?
If you desire more content in a Topic, consider reaching out to the Admin or Content Creator or using the contact information provided, such as support@postbeyond.com.
