The PostBeyond Dashboard provides administrators with a comprehensive view of user engagement and post performance on the platform. It includes metrics such as interaction breakdowns by social network and geography, total shares, user engagement statistics, and the Earned Media Value (EMV) of shared content. Additionally, the dashboard offers export capabilities and customization options for time periods to tailor the data insights to specific needs.
Dashboard: An Overview
Check out your Dashboard for an overview of how your posts and users are doing on the platform.
The Dashboard is the first screen you will see as an Administrator when you log in to your PostBeyond account. It provides an overview of how your posts and users are doing. Here are the different metrics you can find on this page.
Interactions Breakdown
Here you will find a breakdown of all of the interactions with posts shared by your users in the designated time period.
Breakdown by Social Network
This chart shows the breakdown of interactions by social network.
Interactions Map
This map shows the geographical breakdown of interactions with content shared. The darker blue indicates a higher interaction rate, while the lighter blue indicates a lower one.
Export
Here you can export the information on your Dashboard as a PDF file.
Below are some resources to help you with leaderboards on PostBeyond:
Contact Us
If you have any questions, feel free to reach out to us at support@postbeyond.com
Time Period
This section allows you to select the time period you want your dashboard to display. By default, the options include 7, 14, and 30 days. If you need to specify a different range, you can do so by selecting 'Custom'.
Shares
This indicates the total number of shares across all social networks from all of your users.
Shared Posts
This is the percentage of published posts that have been shared at least once by users.
Top Five Posts
Here you will find the posts that have been shared the most times by your users.
User Engagement
User engagement metrics reflect the level of user interaction with the content over a certain period. This includes the percentage of users who have suggested posts, shared posts, and viewed posts.
Leaderboard
Here you will find the top five users on your leaderboard.
Interactions
This number denotes the total number of clicks, likes, re-shares, and comments on posts shared by your users.
This shows the calculated Earned Media Value from posts shared during the designated time period.
What is the purpose of the PostBeyond Dashboard?
The PostBeyond Dashboard is designed to give administrators a detailed overview of user and post performance on the platform, including interactions, shares, and user engagement metrics.
Can I export the data from the PostBeyond Dashboard?
Yes, you can export the information displayed on your Dashboard as a PDF file for further analysis or reporting.
How does the PostBeyond Dashboard display interactions geographically?
The Interactions Map on the dashboard shows the geographical distribution of interactions with shared content, using different shades of blue to indicate varying levels of interaction rates.
What does Earned Media Value (EMV) indicate on the PostBeyond Dashboard?
Earned Media Value (EMV) represents the calculated value of the exposure and interactions generated from posts shared during the designated time period, essentially quantifying the benefit gained from user shares.
How can I customize the time period for the data displayed on my Dashboard?
You can select a time period for your dashboard data from the default options of 7, 14, and 30 days, or specify a custom range by selecting the 'Custom' option.
