If you're having difficulty creating a report dashboard to track the number of page views your knowledge base receives in AdvocateHub, this guide is for you. You may be unsure of the process to set up such a report, how to select the right metrics, set the appropriate filters, and choose the correct visualization. This can be a challenge if you're looking to monitor the usage of your knowledge base but lack the technical knowledge to set up a tracking system.
Solution
To create a report dashboard to track the number of page views your knowledge base receives, follow these steps:
- Log in to your Admin Account.
- Navigate to the Dashboard section and select
New Dashboard. - Choose
Group Dashboardif you wish to share it with other admins, or selectPersonalif you prefer not to share. - Once the Dashboard is created, go to the corresponding Dashboard and click on
Edit Dashboard. - Click on
Add, then selectVisualization, and select theContent Page Viewsoption as per your case. - Select all the fields you would like to include in the Dashboard.
Summary
Creating a report dashboard to track page views in AdvocateHub involves logging into your admin account, creating a new dashboard, selecting the appropriate visualization, and choosing the fields to include. This allows you to monitor the usage of your knowledge base effectively.
- Can I share my dashboard with other admins?
Yes, you can chooseGroup Dashboardwhen creating a new dashboard to share it with other admins. - Can I select which fields to include in my dashboard?
Yes, you can select all the fields you would like to include in your dashboard when setting it up.
