The article provides a step-by-step guide on how to automate the sending of invitations for "Invite a Colleague" challenges using Zapier. It details the process of setting up a challenge template, creating a Zap with Webhooks, configuring triggers and filters, and customizing email settings to streamline the invitation process within an AdvocateHub.
As a pre-requisite, you will need to have a Zapier account in order to begin this process. The free Zapier account comes with 5 "Zaps" and 300 "tasks" (i.e. events) per month.
We will be working with the challenge template entitled, "Invite A Colleague To Your AdvocateHub." You can access it by going to Challenges > Add a Challenge and searching for "Invite A Colleague." We'll make one slight modification, though. This challenge should have one field for First Name and one for Last Name rather than just one field for the invitee's name.
Setting up the "Zap"
We will begin by going to Zapier and starting the Zap set-up process. Follow the steps below:
1. In Zapier, click on Make a Zap in the top navigation bar.
2. For the Choose a trigger app , search and choose Webhook by Zapier and select Catch a hook for the trigger.
3. For the A ction app , choose your email sending platform or choose Email by Zapier if the platform you use is not listed.
Note: We will continue this process using Zapier's Email option, but configuration will be similar for other platforms.
4. Click Continue and copy the URL provided.
5. Open a new tab or browser window and go to your Hub.
6. Navigate to Settings > System > Webhooks and click on Add a Webhook
7. Give your webhook a relevant name, and paste the Zapier URL into the Webhook Provider URL
8. Scroll down in the webhook pop-up and check the box beside Questions Answered
9. Scroll down to the bottom an save your webhook
10. Now, return to the tab/window where you are working on your Zap and click Continue to Step 3. In Step three, you will have to configure your account with the email sending service of choice
11. Continue to Step 4, Filter Web Hook triggers , where we will add some filters to make sure we are getting information from the correct challenges
12. Click on the arrow beside the first field
Wait! Zapier will likely present you with a pop-up now. Please do the following:
13. Click "Okay, I did this" for the first two steps. Once Zapier tells you that it is waiting for your changes, continue to the next step
14. Return to your hub in another tab/windows, and switch to Advocate View
15. Now, find the Invite a Colleague challenge you created for this purpose
16. Complete this challenge using some very obvious inputs - e.g. FIRST NAME, LAST NAME, EMAIL (you'll see why this is important later)
17. Come back to your Zapier window and notice that Zapier has picked up your changes
18. Now, add a custom filter: Source Name | (Text) Exactly matches | ( Your challenge's headline)
19. Continue to Step 5 to configure the email settings
How to Insert Fields:
Click on the "Insert fields" buttons to insert the appropriate AdvocateHub fields into to the corresponding email fields. You can easily find the correct invitee fields by looking for Parameters[Responses][###] . This is where using FIRST NAME, LAST NAME, EMAIL to complete the challenge earlier becomes useful.
Any Contact fields are for the Advocate who wants to invite this person. Take a look at my example below for inspiration:
20. After configuring everything, continue on to test and save your Zap
Do I need a paid Zapier account to set up automatic invitations for "Invite a Colleague" challenges?
No, you can use the free version of Zapier, which offers 5 Zaps and allows for 300 tasks per month, which should be sufficient for basic automation needs.
How do I ensure that my Zap only triggers for the correct "Invite a Colleague" challenge?
You can ensure this by adding a custom filter during the webhook trigger configuration step, where you match the source name exactly with your challenge's headline.
What should I do if my email sending platform is not listed in Zapier's action apps?
If your platform is not listed, you can use the "Email by Zapier" option to configure the email settings for your invitations.
How can I test if my Zap is set up correctly?
After completing the email configuration, you can test your Zap within Zapier to ensure that it is functioning as expected before saving and finalizing the setup.
What is the purpose of using placeholders like FIRST NAME, LAST NAME, EMAIL when completing the "Invite a Colleague" challenge?
Using clear placeholders helps you easily identify and insert the appropriate AdvocateHub fields into the corresponding email fields during the email configuration step in Zapier.
