Due to recent API updates by LinkedIn, users may encounter issues when attempting to sign in or share content using their LinkedIn accounts. The solution involves re-associating the LinkedIn account with the user's community profile, which can be done by logging in through alternative methods and updating the profile settings. This process is designed to be straightforward and quick to minimize user inconvenience.
Due to some API changes performed by LinkedIn, LinkedIn associations may have become invalid. In order to use LinkedIn to login or share content, we will need you or your advocates to re-associate the LinkedIn account to the hub's profile. The good news is that this is a very quick fix!
Here's what you and your advocates need to do:
- If you have associated a Facebook or Twitter account with the community, or you login via an e-mail address and password,
- Login to the community using one of aforementioned methods
- Re-add your LinkedIn account by clicking on your profile icon in the upper right corner, clicking Profile, selecting Edit Profile.
- From there, you can add your LinkedIn account from the Social tab.
- If you usually login using only your LinkedIn account, please click Forgot Password and reset your password to gain access to your account. Once you are successfully logged in, please follow Step 1 as well
We apologize for any inconvenience this may cause.
What should I do if I can't log in to the community with my LinkedIn account?
If you're unable to log in with LinkedIn, use an alternative method such as Facebook, Twitter, or email to access your community account, and then re-add your LinkedIn account through the profile settings.
How do I re-associate my LinkedIn account with my community profile?
Log in using an alternative method, click on your profile icon, select 'Profile', then 'Edit Profile', and navigate to the 'Social' tab to re-add your LinkedIn account.
What if I only use LinkedIn to log in to the community?
If you only use LinkedIn, select the 'Forgot Password' option to reset your password. Once you've reset your password, you can log in and follow the steps to re-add your LinkedIn account.
Will I lose any data or settings by re-associating my LinkedIn account?
Re-associating your LinkedIn account should not cause you to lose any data or settings within your community profile. It simply re-establishes the connection between your LinkedIn and community accounts.
