This article provides detailed instructions for upgrading to version 3.529 of the AdvocateHub Salesforce Package for users of Salesforce Classic. It outlines the process for users upgrading from versions 2.38 - 2.58 and for those already on version 3.0. The article emphasizes the importance of reconnecting the Influitive-Salesforce integration post-upgrade and updating components in the page layouts, including the Account and Opportunity objects.
Upgrade instructions from 2.38 - 2.58 version to 3.529 version for Salesforce Classic users. For 3.0 version users, you must install the new package link below; no page layout changes are needed. You can click the link below and log in with the Salesforce instance you want to install:
This AppExchange Package is the newest and latest version (Version 3.529).
- New References Dashboard Report that tracks revenue impacts and win rates
- Improvement of Reference criteria matching tool
- Reference Request Tool Configuration settings
- Mark Important notes as mandatory or optional
- Choose Account and Opportunity Contact Prospects or just Opportunity Contact
- Choose whether to hide or display the recommendation criteria step or display anonymized contacts
- Bug fixes
Updating the Influitive AppExchange Package 3.529
AppExchange Package Link
- Production: https://appexchange.salesforce.com/appxListingDetail?listingId=a0N3000000B3GQGEA3
Sandbox: https://test.salesforce.com/packaging/installPackage.apexp?p0=04t3o0000011PwT&isdtp=p1
Select Install for All Users , mark the checkbox and click Upgrade .
- Once Installation is completed, you will see the completion message or email. Login to your Salesforce to check if the package version (Setup > Platform Tools > Installed Packages > Package Name: AdvocateHub > Version Number 3.5+).
Notes:
After the AppExchange package is updated, please ensure the Influitive-Salesforce integration in your Hub is still connected.
- Browse through the integration library until you find the Salesforce integration and click Manage .
- To confirm your credentials, navigate to the Setup Tab and change the AppExchange version to the version you've just installed (3.529) and click Save.
Updating Components in the Page Layouts
After installing and deploying the updated AppExchange package, the Salesforce administrator will need to modify a few object's layouts to add the Influitive integration components to remove the old components and replace them with the new components.
For further information on modifying Salesforce Page Layouts, please visit this Salesforce Help Page .
Page Layout Checklist
| Objects | Components |
| Contacts |
| Account |
| Opportunity |
| Salesforce Dashboard |
Account Object
If you have added these components, please skip this step.
Influitive Acts of Advocacy Table (by Account)
- In your Salesforce instance > Go to Setup > Customize > Account > Page Layout > Select Layout
- In Related List, drag and drop the “Influitive Acts of Advocacy” into the layout
- Once added, click on the wrench icon on Influitive Acts of Advocacy
- Advocacy Type - https:https://influitive-supportdesk.zendesk.com/hc/en-us/articles/15750759014674-Acts-of-Advocacy
- Requested By - If it's a reference related act of advocacy, this will show the name of Salesforce user who requested the challenge.
- Opportunity - If it's a reference related act of advocacy, this will show the Opportunity for the prospect in the reference challenge.
- Here's what the Influitive Acts of Advocacy Table will look like. It will contain all the Hub activities done by the Hub members from the Salesforce Account.
References Received via Influitive (by Account)
Go to Visualforce Page > Drag and Drop " ReferencesRelatedListPage" onto the layout
- Click Save to save the Layout.
Opportunity Object
If you have added the References Received Components, please skip this step.
- In your Salesforce instance > Go to Setup > Customize > Opportunity > Page Layout > Select Layout
- Click on the wrench icon and add the following fields: Acts of Advocacy Name (Required), Advocacy Type, Source Title, Date Occurred, Prospect, Content, Contact, Opportunity, Prospect > Click OK.
- Click Save Layout
- Here's an example of what this looks like. This component will include all reference activities the Opportunity has received.
Do I need to make any page layout changes when upgrading from version 3.0 to 3.529?
No, if you are upgrading from version 3.0, no page layout changes are necessary.
What should I do after installing the updated AppExchange package?
After installing the update, you need to ensure that the Influitive-Salesforce integration in your Hub is still connected and modify the layouts of certain objects to add new Influitive integration components.
Where can I find more information on modifying Salesforce Page Layouts?
You can visit the Salesforce Help Page for detailed information on modifying Salesforce Page Layouts.
Is it necessary to add the Influitive Acts of Advocacy Table to the Account object if it's already been added?
No, if you have already added these components to the Account object, you can skip this step.
