This article provides a comprehensive guide on integrating Klaviyo with Influitive, covering authentication, profile data sync, groups & lists sync, and event & metrics sync. Klaviyo's marketing automation platform can be directly integrated with Shopify, enhancing e-commerce marketing strategies.
The integration between Influitive and Klaviyo allows for seamless synchronization of profile data, groups, lists, and events. This article details the steps required to set up and manage these integrations effectively.
Authentication
To enable Influitive to communicate with Klaviyo's API, generate a new API key in Klaviyo under Account Settings > API Keys. Input your Public API key and the Private key you generated into the Influitive integration page for Klaviyo to authenticate and access various integration points.
Profile Data Sync
The Profile Data Sync allows for bi-directional synchronization of profile fields between Influitive and Klaviyo. Select a Klaviyo List to import contacts into Influitive and set up field mappings with sync options such as One Time Pull, Continual Push, Continual Pull, and Bi-directional Sync. These sync operations run every 2 minutes.
Groups & Lists Sync
Sync Influitive groups with Klaviyo's Lists to maintain segmentation and marketing campaign alignment. Match Influitive groups with Klaviyo Lists to push updates every 2 minutes. Note that only group additions are synced, not removals.
Event & Metrics Sync
Sync Klaviyo Metrics with Influitive to award points for events. Metrics are synced every 2 minutes, including historical data. Custom events in Influitive will appear as shown below.
Push Events
Send events from Influitive to Klaviyo to trigger workflows or record activities for email campaigns. Events are pushed instantly as they occur, and will be visible in Klaviyo as shown.
What is Klaviyo?
Klaviyo is an SMS & Email marketing automation platform that includes a free Customer Data Platform with integrations, data visualization, and more.
How often do the sync operations run between Influitive and Klaviyo?
Sync operations run every 2 minutes, ensuring that changes to fields and group memberships are updated promptly.
Can I sync events from Influitive to Klaviyo?
Yes, by enabling the Push Events option, you can send events from Influitive to Klaviyo to initiate workflows or log activities for email campaigns.
