The article provides a step-by-step guide on setting up a TrustRadius challenge that automatically verifies review submissions within the Influitive platform. It emphasizes the importance of configuring API integration and maintaining unique API codes for each challenge to ensure proper tracking and verification. Additionally, the article notes that TrustRadius performs a quality assurance process before publishing reviews and provides instructions for setting up multiple challenges for different products or campaigns.
Now that you have configured the integration in Influitive and TrustRadius , you can create a challenge which automatically verifies whether or not a review has been submitted to TrustRadius.
Please note that TrustRadius Team will perform a quality assurance process for reviews submitted before publishing it to the page, therefore, not all review submission will be eligible to be published. Any questions about this, please contact support@trustradius.com
Part I: Creating a TrustRadius integration challenge
1. Head to Program > Challenges > Add a New Challenge > Blank Challenge .
The icon of the stage will look like this:
2. Once the API Integration stage is added to your challenge, it should appear as below:
3. Enter the API Integration stage to edit.
Stage Description
You must include a specially formatted link to your product's TrustRadius reviews page in the Stage Description. This will allow the challenge to recognize who has actually submitted and written a review.
1. In another tab/browser, go to your TrustRadius product pag e on TrustRadius.com - (you can search for your product and find the URL when you see your product), and copy its URL. In this article, we will use Influitive’s own product page as an example: https://www.trustradius.com/welcome/review/influitive-advocatehub
2. Head back to the tab/browser with the challenge, and in the API stage, paste your TrustRadius URL in the Stage Description.
3. Copy the following text, and paste it directly after the TrustRadius URL (without any space in between):
?target-influitive-advocateid={{contact.id}}&target-influitive-stageapicode= tr-review1 &target-influitive-stageeventtype=TrustRadiusReview&target-influitive-trevent=submit-review
4. Using markdown, add a text advocates will click on using the following format [Link Text](http://url.com) . Replace the bolded text below with your own information:
[Review Product Name on TrustRadius!]( https://www.trustradius.com/welcome/review/YOUR_PRODUCT_PAGE ?target-influitive-advocateid={{contact.id}}&target-influitive-stageapicode= UNIQUE_API_STAGE_CODE &target-influitive-stageeventtype=TrustRadiusReview&target-influitive-trevent=submit-review)
[Review Influitive on TrustRadius!]( https://www.trustradius.com/welcome/review/influitive-advocatehub?target-influitive-advocateid={{contact.id}}&target-influitive-stageapicode=tr-review1&target-influitive-stageeventtype=TrustRadiusReview&target-influitive-trevent=publish-review )
API Stage Configuration
1. Set the "allowed event types" to: TrustRadius Review
2. Set the API Code to tr-review1 (or the unique API Stage code)
Finalizing the Challenge
When you're done with all the technical details above, like any challenge, all that's left is to assign a point value , Save , target and Publish it.
NOTE: It is important that you publish the challenge - otherwise, the integration will not work.
Part II: Setting up additional TrustRadius challenges
If your organization has multiple products, or you want to create a separate challenge for a campaign, you may find yourself in need of a second (or third) TrustRadius review challenge. No problem! To execute this, you'll need to understand a couple of things about the stage configuration we discussed above.
Key Point #1:
The API Code field in the API Integration stage must always be identical to the target-influitive-stageapicode= portion of the TrustRadius URL you send advocates to.
Key Point #2:
The API Code and the URL value target-influitive-stageapicode= values must always be unique for each new challenge you create. This lets TrustRadius know which challenge should be completed when that product is reviewed.
Thus, when you create new challenges, just change the API Code (to whatever you want - as long as it is different than the other challenge stages) and the target-influitive-stageapicode= value in the URL and you're all set. Remember that these must always be different than the values used in other challenges.
Examples
Challenge #1
- URL to link to: https://www.trustradius.com/welcome/review/YOUR_PRODUCT_PAGE?target-influitive-advocateid={{contact.id}}&target-influitive-stageapicode= tr-review1 &target-influitive-stageeventtype=TrustRadiusReview&target-influitive-trevent=submit-review
- API Code: tr-review1
Challenge #2 (Same product, different campaign)
- URL to link to: https://www.trustradius.com/welcome/review/YOUR_PRODUCT_PAGE?target-influitive-advocateid={{contact.id}}&target-influitive-stageapicode= tr-review-MARCHMADNESS &target-influitive-stageeventtype=TrustRadiusReview&target-influitive-trevent=submit-review
- API Code: tr-review-MARCHMADNESS
Challenge #3 (Different Product)
- URL to link to: https://www.trustradius.com/welcome/review/ YOUR_OTHER_PRODUCT_PAGE ?target-influitive-advocateid={{contact.id}}&target-influitive-stageapicode= tr-review-OTHERPRODUCT &target-influitive-stageeventtype=TrustRadiusReview&target-influitive-trevent=submit-review
- API Code: tr-review-OTHERPRODUCT
How does the auto-verification of TrustRadius review submissions work?
Auto-verification works by including a specially formatted link with unique API codes in the challenge description, which allows the system to track and verify review submissions automatically when a review is submitted to TrustRadius.
What should I do if I want to create multiple TrustRadius challenges for different products or campaigns?
For each new challenge, you must use a unique API Code and update the target-influitive-stageapicode value in the URL provided to your advocates. This ensures that each challenge is correctly identified and marked as completed when a product is reviewed.
What happens after a review is submitted to TrustRadius?
After submission, the TrustRadius team performs a quality assurance process to ensure that the review meets their publication standards. Not all submissions may be eligible for publication.
Who should I contact if I have questions about the review publication process on TrustRadius?
If you have any questions regarding the review publication process, you should contact support@trustradius.com for assistance.
