This article explains the differences between "Expired" and "Unpublished" statuses in the context of challenges or rewards within a content management system. It details how each status is applied and what it signifies for the visibility of the content to end users.
Understanding the distinction between "Expired" and "Unpublished" is crucial for managing content effectively. Below is an explanation of each status.
Unpublished Status
The Not Published tag appears when a challenge or reward has been created but not yet made public. This tag is visible under the headline on the Challenge Editing page and on the Challenges tab. A challenge may also be marked as Not Published if an administrator manually unpublishes it. Unpublished challenges are not visible to advocates until they are published.
Expired Status
The Expired tag differs from Not Published. It is assigned when a challenge is made public using Publishing Options and has a set end date. The challenge will be unpublished at the specified time and date, and the Expired tag will indicate that the challenge was once active but is no longer due to the end of the publishing timeframe.
In the Challenges tab, filters can be used to display only Expired or Unpublished challenges.
What does the "Not Published" tag mean?
The "Not Published" tag indicates that a challenge or reward has been created but is not yet visible to advocates. It will remain in this state until it is published by an administrator.
How does a challenge become "Expired"?
A challenge becomes "Expired" when it reaches the end date set in the Publishing Options. At this point, it is automatically unpublished and marked as expired, indicating it was once active but is no longer available.
How can I view "Expired" or "Unpublished" challenges?
You can filter for "Expired" or "Unpublished" challenges using the filter options available in the Challenges tab of the content management system.
