AdvocateHub has introduced a feature that allows admins to permanently delete members or contacts, ensuring the complete removal of their data and anonymizing their discussion contributions. This process is irreversible and includes the deletion of various user-related content such as challenge responses, activity feeds, and leaderboard standings. Admins must have 'Manage Users Permission' to perform deletions, and they should be aware of the difference between deleting and disabling accounts.
AdvocateHub admins will now be able to delete a member or contact from the hub, removing all associated data and anonymizing discussion contributions. When a Contact (member or nominee) is deleted, all of their data is removed; including challenge responses, profile fields, activity feed, leaderboard, reporting, referrals, profile info any acts of advocacy.
Any discussion post that was posted by the deleted users will still appear in the Discussions topic. However, the username will be anonymized. Here's an example:
You can manually delete the Discussions post by clicking the trash can icon on the Discussions post
IMPORTANT! Once the contact is deleted, there is no way to retrieve the contact anymore. Please make sure to double-check your selection before doing any deletion.
How to delete contacts
You can now find a Delete option on member profiles, on the Invite List, and on the slide-out profile that appears when clicking on a member in the Advocates list.
Member profiles
- In the Admin view > Members > Advocates Tab > Search for the user to delete > Click on their name and click See full profile.
- Inside the full profile, click on the pencil icon > Select Delete Member.
- You will then get a confirmation pop-up to confirm the deletion. Select Yes, delete Member .
- The deletion process will commence and once done, you can check your Notification center bell icon to see the progress and completion of the deletion task.
Advocates Tab
- Click on the three dots next to the user's name > Choose Delete Member
- Alternatively, click on the user's name, on the right-hand side profile slide out, click Actions > Delete Member
- You will then get a confirmation pop-up to confirm the deletion. Select Yes, delete Member to proceed.
Delete in bulk
- To delete in bulk, head over to the Members Tab > Advocates Tab
- Mark the boxes next to the names of the users to delete
- Once done, click on the Actions button > Select Delete Members
- If more than one user is being deleted, you will need to type in DELETE in order to confirm the deletion. Please note that once deleted, the contact cannot be retrieved anymore.
Invite List
Administrators can also delete Not joined users or Nominees from the Invite List. Here's how to do this:
- In the Admin view > Go to Members > Invite List
- Click on the name of the user to delete and it will open a new tab to show the full profile of the user
- Once opened, click on the pencil icon and select Delete Member
Delete in bulk
- To delete multiple users from the Invite List in bulk, head over to Admin view > Members > Invite List
- Mark the checkboxes next to the names of users to delete
- Once you're ready to delete, click on the delete button
Deleting vs Disabling
When should I use Lock accounts?
- When a real contributing member of your program is no longer engaging, no longer a customer, or for some reason is no longer valid for your program.
- When you want to block a specific user/email address from logging in
- For a Contact or Member that may need to be re-enabled in the future
- When you want to limit a user from further participation but keep their contributions recorded in the Hub.
When should I use Delete members?
- Test accounts created for you or your team-mates
- Real members who request their data be deleted
- Invited Contacts who did not Join that need to be cleaned up
- When you are content to remove all contributed content by the user
- Badvocates who are spamming content that needs to be removed. *Please note that once deleted, they will be able to re-join the Hub with the same email address via join code or open sign up.
What happens to the discussion posts of a deleted user?
Discussion posts made by a deleted user will remain visible but will be anonymized, removing the association with the user's name.
Can deleted contacts be retrieved?
No, once a contact is deleted, it cannot be retrieved, so it is important to double-check before proceeding with the deletion.
Is there a limit to the number of contacts that can be deleted at once?
There is no maximum number of deletions, but deleting a large number of contacts, such as over 10,000, may take longer and may require assistance from support@influitive.com.
Who has the permission to delete users from AdvocateHub?
Only corporate users with 'Manage Users Permission' can delete users, which is typically included in the Administrator Role.
What should I do if deleted contacts reappear in the Invite List?
If deleted contacts reappear, check if you have a Salesforce integration enabled, as this may be causing the issue.
