Public Content and Discussions
Introduction
With our new Public Content and Discussions features, admins can make Discussion Categories and Content Sections to make available publicly on the web. This means that any content made public will be searchable on and accessible from search engines (i.e. Google, Bing, Lycos, AltaVista). Additionally, any user who obtains a link to the customer’s AdvocateHub will also see the publicly available Content pages or Discussions Categories.
Here's an example of a public discussions forum:
Implementation
It is quite straightforward to make a Custom Content Section or Discussions Category open to the public. Everything is done in the Targeting of the Category.
- Click on the “Discussions” menu on the Admin View navigation bar
- Choose “Category Management”
- Click the three dots to the right of the Category you wish to make public
- Select “Edit”
- Go to the “Targeting” tab
- Select “Public” under the “Target Audience” heading (pictured above)
- Click the “Save” button
The Category will now be open to all members and public users. You will notice that you cannot add any targeting criteria for members when a Category is made public. This means that if a Category is public, all members will be able to see it as well, regardless of any previous targeting you may have set.
Custom Content Sections
- Click on the “Content” menu on the Admin View navigation bar
- Choose the section you wish to make public
- Click the “Edit” button
The entire Content Section will now be open to all members and public users. You cannot change targeting for individual Content Categories, which means that every Category with a public Section will be public as well.
You will notice that you cannot add any targeting criteria for members when a Section is made public. This means that if a Section is public, all members will be able to see it as well, regardless of any previous targeting you may have set.
Public Content and Discussions Flow
There is a slight difference with what users will see when they land on a Hub that is Open Sign-up (i.e. anybody can sign up) versus when they land on an invite-only Hub (i.e. they must receive an invitation to join) versus Gateway or SSO Hubs.
Open Sign-up Hub
In an Open Sign Up Hub, when the users head over to a public discussion forum or content, the top right of the page, will show a “Sign Up” and “Log In” button, as pictured below.
Invite-only Hub
When a user accessed a public discussions in an invite only Hub, meaning that only invited Hub members can enter / join the Hub. The top right of the page, you will only find the “Log In” button, as pictured below. This is because users cannot sign-up for invite-only hubs as they would need to be invited to the Hub. Additionally, if a public user clicks on a “Reply” button (pictured below) in a Discussions Topic on an invite-only Hub, they will be prompted to sign-in, with no option to sign-up.
Gateway Hubs
Some Hubs make use of the “Gateway” feature, which provides a landing page that lists all AdvocateHub-based programs/communities which belong to the same company (i.e. Influitive customer).
In these situations, visiting an individual Hub directly will provide the same experience as any Hub with public Discussions or Content. The only difference is that clicking the “Log In” button would bring users to the “Gateway” page from which they can sign in or request access (if applicable).
What about Hubs with Single Sign-on (SSO)?
There is no special behaviour that affects Public Content and Discussions when SSO is enabled. If a Hub uses SAML or OAuth 2.0 with Single Sign-on enabled, clicking on the Log-in will put the user through the SSO sign in flow (instead of the Influitive login system).
Member vs Non-member
Member | Non-Member |
Discussions: Comments posted in the public categories will be visible to the public audience | Discussions: Can be read public discussions, but will need a login to respond, tag others, like a post, upvote an idea, participate in polls |
Content Pages: Comments posted in public pages will be visible to the public audience | Content Pages: Can read public content pages, but will need a login to respond |
Challenges: Can participate and earn points for completing challenges | Challenges: Cannot see or participate in challenges |
Rewards: Can redeem points for rewards in the rewards catalog | Rewards: Cannot see or redeem rewards |
Messaging: Can participate in 1:1 and group chats with other members | Messaging: Cannot message other members |
