Targeting: Tips and Tricks
Targeting: A General Overview
The targeting screen is generally the same for rewards, challenges, groups, and channels. You can access the targeting panel by going to any of these pages, clicking on the Edit
The first option in the Include Members area is Everyone. When selected, everyone in your hub will be included in the Group. This is useful for the cases when you want to include every advocate except a few people or a specific group of people added through the exclusion rule. Remember that exclusion rules always take precedence over inclusion rules.
For Group targeting, if you would like to only include manually added users in the group, simply leave the targeting rules empty.
To add a new line of the rule in the new Targeting UI, click on the Add rule button. To delete a rule, click on the 'X' next to the rule that you'd like to remove.
If you would like advocates who match specific criteria to see (or be excluded from) the Group, choose the criteria from the dropdown button. You will also note the option to include (and exclude) members who
Differences between All and Any
Please view this beautifully made InfluiTip video to explain the difference between using the "Any" or "All" switch - InfluiTip #12: Targeting Limits. Note that the Targeting UI is now different from the video since we've made improvements.
Criteria for inclusion falls into these groups:
- Individuals: Specific advocates (you can search by typing their Name, Email address, or Title).
- Group: The member is a member of a specific group in the Hub.
- Advocate Info: Criteria based on information about the member (e.g. Industry, Region, Title, etc.). You can also choose fields with blank values.
Behaviour : How the member behaves in your hub (e.g. Engaged, Not Engaged, completed specific challenges, earned badges, etc.). - Response: Includes/Excludes advocates based on their response to a question from a specific challenge. You can choose to segment an exact response or a response which contains a certain word
Never forget to target: If you implement segmentation from the start, it will boost your Influitive community's ability to adapt to future changes. You should create a group called "starter" or "all advocates" and add all of your advocates into that group. You should not leave anything targeted to everybody because that can open up a can of worms if you decide to make changes in the future (such as inviting a different segment of customers to your hub).
Basic
Targeting Example
A template for this is available in the Challenge Template library. Finding out an advocates location is great
You can target something to a location in that item's targeting settings, as seen below.
Workflow example
- Advocate
completes the ' Where are you located?' challenge and answers 'Canada'. - Advocate is placed in the Canada group (by targeting the group to the response Canada). Everyone who answers Canada will now be in this group.
- A reward for an Amazon gift card in Canadian currency is available. This reward is targeted
to people in the Canada group. Now people in the Canada group will see this reward, and it will be hidden from everyone else.
Targeting Limits
Why did we set these limits?
What does that mean?
- Create Group 1 and include those who completed the first 10 starter challenges.
- Then create Group 2 and include those who completed the last 10 challenges.
- Once done, target the Challenge to the members who are members of both (select All) Group 1 and Group 2. This way, it will include everyone who completed the 20 starter challenges.
Copying and Pasting Targeting Options
If you are copying and pasting options into targeting and want to make sure each item is separated properly, add a double comma (,,) between each item. For example, here's a double comma-delimited list of World regions: Africa,,Asia,,The Caribbean,,Central America,,Europe,,North America,,Oceania.
Tip: If you have a long list of options where adding the double commas manually would take too long, use the "Find and Replace" feature in your favourite text editor. Set it to find whatever current delimiter (e.g. a single comma, a space, a line break) is in the list and replace it with ",,".
When you paste your list you will see an option to separate the values, clicking on it will itemize each item separated by the double comma.
