Challenge Template Library
The challenge template library provides you with many best-practice templates that are ready to use in your AdvocateHub.
  1. From the Challenges page, click on the Add a Challenge button. This will bring you to the template library (seen above).
  2. The latest templates will always be at the top, just beneath the template category filters.
  3. Click on a category to find a challenge, or search for a template.
  4. After clicking on a template, you can click the Preview Template button to see what it looks like and click User Template to start customizing it.
While templates are a great way to get started, you should always customize them so that they better suit your audience. Often, there are areas which require customization, such as adjusting links or names.
