How to Add Custom Badges and Badge Icons
It’s easy to set up a custom badge with a unique picture on your AdvocateHub.
First, head over to the drop-down menu under your name and select settings. In settings, select Levels & Badges from the left hand menu. Here we can add a badge by clicking Add Badge in the right corner. This will create a new badge, and you'll be able to upload your own badge icon.
The dialogue below shows us the Add Badge window. Give your badge a name and description.
Scroll down and you’ll see where you can upload a custom picture for the badge photo. Select Choose File and select the picture on your computers hard drive that you would like to use.
We recommend you use an image that is approximately 70 pixels by 70 pixels. A transparent background will ensure the image doesn’t have a box around it.
You’ll have to set rules for your badge. Who can win it? When will it be rewarded? For example, perhaps you want it awarded when someone has completed 3 Twitter challenges.
Once you’ve set the rules, click on Create Badge. The new badge will be visible in the No Level section of Levels & Badges.
You can drag the badge icon to any level you’ve set up, so that it is only available to Advocates of that particular level.
Looking to create custom badges? Check out this free custom badge designer.
